- Alex
- Oct 23, 2020
- 33
- 3,061
- 5,906
- Cleveland OH
- 2022 Badlands
- Badlands
Check this out, might seem like a janky solution, but if they fit it will certainly save the time of fabricating something and would be easy in out. The inside dimension of that opening is 2.5" x 2.5" if I measured correctly. The ID of these table leg end plugs range between 2.49" and 2.64" and are rubber or flexible plastic so should actually be a decent fit. The OD is 3"x 3" so they will hang over just a bit on all four sides. You might need to trim off some of the bottom part of the inside plug, but maybe not even. For $10.00 for two it will be one of the cheapest fixes I have purchased so even if they don't work it is little lossfor $2k I shouldn't have to use gorilla tape. If they wanted people to have easy access to the wiring connecting, how hard would it have been to make an access panel with 2 threaded bolt holes?
