Reverse gear torque is useless
Outforarip
Jonathan
British Columbia
1979 bronco 2021 Bronco wildtrak
I was stuck in a river bed over weekend and could not back my way out of situation. The torque provided in reverse gear is completely useless in a off road situation. Is there a way to bypass and have full power in reverse? Or is that the actuating gearing causing that in automatic transmission?
I have a 2021 wildtrak
dgorsett
colorado
F250, Mustang, Explorer
Did you use low range?
Outforarip
Jonathan
British Columbia
I was in 4l both lockers ingaged
But I tried 4h aswell reverse had no torque
Outforarip
Jonathan
British Columbia
Usaully if stuck or close to u move forward and back work urself out
Only could move forward no power in reverse gear. Which made situation worse. Reverse is a big part of off-roading. Could there b something wrong with it ?
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
Did you turn the traction control off?
dgorsett
colorado
First gear is 4.7xxx to 1, reverse is 4.8xxx, so torque is essentially the same. Trail condition to the rear could have been different
BTW, these ratios are pretty darn good for an auto
Ducati1098
I’m not sure what you mean by “full power” in reverse, but there is nothing to bypass. It’s either reverse or no reverse.
Also reverse has the lowest gear ratio, so it should have the most torque out of any gear.
dgorsett
colorado
Outforarip
Jonathan
British Columbia
Would have been easier goin back way I came goin forward was a problem lol
So I guess that’s just what comes with a 10 speed auto
No power in reverse ?
Doesn’t that seem like a problem in a off road vehicle?
Outforarip
Jonathan
British Columbia
You can’t spin the tires in reverse to get momentum so in a mud /snow/sand situation it makes backing out of said situation impossible can only continue forward
Which in off roading isn’t always a option
Broncoman7072
Pell City, Alabama
72 Bronco, 70 Bronco
This was bouncing off the rev limiter in both forward and reverse while in 4L. Reverse is geared lower so less wheel speed. Didn't notice low power in reverse.
Outforarip
Jonathan
British Columbia
yah that looks bearable mine felt like traction control was stuck on I don’t believe I woulda back out of that .
Was that 4h ?
Broncoman7072
Pell City, Alabama
That was in 4L
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Loose nut behind the wheel
