Rear window rattle? Anyone have and solve this??
SeanMTX
New Mexico
2023 Bronco BD
Before the internet tars and feathers me, yes, I know I didn't buy a luxury sedan and a vehicle that is made to have parts removed will always have some noises or rattles.
That said, I have a rattle in the rear that seems like it's coming from the window itself. It's almost constant and happens on any terrain. Anyone have this issue and resolved it? I'd love to know where it originates from.
Thanks!
TXBronco1313
I had similar thing happen to me in my 2 door. I kept hearing rattling noise so thought it was one of the rear windows. It was driving me nuts so I had my girlfriend drive while I sat in the back. turns out, it was something inside the tailgate (it's a known issue with inner hinges I think)and not the back windows. Not sure if the same thing is happening to you but it may not be the window itself but rather the tailgate door
SeanMTX
SeanMTX
New Mexico
2023 Bronco BD
Thanks TX! I'll see what I can figure out. It's maddening to not know where exactly it's coming from. I can't solve it if I can't find it.
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
Besides the potential of something loose in the tailgate the rubber window seal that the tailgate snugs against has a tendency to dry out and sound like squeaking water bottles in a case. Put a coating of a rubber lubricant on it. Ford recommends a lubricant called Krytok purchased from Ford. Works great on the seal and other squeals but is expensive.
TXBronco1313
Have someone drive it up and down the street while you're in the back seat. That's how I ended up finding where the noise was coming from. I was told tailgate noise is covered under warranty and will require a brand new tailgate if i'm not mistaken so in my case I figured I'd rather live with it than have the mechanics at dealership tear through my brand new car. Others recommended spraying WD-40 on the hinges (I'd be careful with that because it is paint thinning)Anyways, good luck
Link to previous tailgate rattle noise
https://www.bronco6g.com/forum/threads/gnarly-tailgate-rattle.20393/
TheGriffin1313
Mongo
2022 Mav
Thanks!
Not sure if anyone mentioned it, did you drive with the rear window open to see if the noise is gone or still there?
Do you have a tailgate table attached? that also may be the source
Dan-O
Dan
Fountain Hills, AZ
2021 Bronco Outer Banks
Thanks!
I have also heard of the rattling sound that comes rear tailgate area and people said it is from some kind of wire loom inside tailgate rattling, I personally have not had this problem.
TXDOZER
Les
El Paso TX
2022 Bronco Basesquatch & 2020 Escalade
Did you find the fix? I've got the same thing. Metal on Metal rattle. Wonder if something came loose inside the tailgate when removing the spare tire mount?
TXBronco1313
TXDOZER
Les
El Paso TX
Thanks.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Thanks!
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Padawan
Porsche Macan GTS
Read and searched and listened. Finally found it. Where the tailgate touches the bottom of window for mine. I ran a piece of cheap door seal to pad the interface. Still works after two years. I asked the dealer to fix and they said into the repair shop and evaluate then repair for couple days. Be very careful with discussion fix here on putting types of lube around ruining back gaskets-many don’t come off.
1st 75th ranger
jeffrey
nj
Thanks!
undderneth door are 2 rubber plugs
pull them off loosen nut puch to outside of door aqnd retighten i did mine it worked
watch you tubes window flop on bronco
