Rear seatbelts flapping with top off -- how to fix?
amazingjason
CA
1987 Samurai, 1966 442
How do you keep the rear seatbelts from flapping with the top off?
Fordified1
Bob
Mid South Texas
ā€˜15 Mustang ecoboost, 4wd Excursion, ā€˜69 Mach 1
Buckle them. Just an idea. Havenā€™t had our tops off yet.
Skott
Missouri
2022 Bronco
I recall trying to buckle last summer with tops & doors off, and the flap was almost worse than just leaving them unbuckled. I pulled over and unbuckled them.
Maybe buckling them, and wrapping the uppers around the headrest or something? Maybe a hook and latch strap around the belts?
Fordified1
Bob
Mid South Texas
1st world problems lol. Our Gladiator had clips just for that reason. Iā€™m with you on eliminating noises and distractions though.
FordOwner
SoCal
a few
I just buckle them and call it good. It does not eliminate noise but it's better than them not being buckled. IIRC it helps to hit the tensioner limit first to keep them tensioned.
Happycampinman
Ford Bronco
Sticker fab seat belt retention. I have them and they work.
Ksjrb03
Tx
F250
Huge oversite on Fords part. I bought some clips years ago when I first got the Bronco, forget what vendor had them, but the adhesive doesn't stick to the Bronco very well and have to redo it all the time.
MFP2241
All you need is $3 worth of double sided Velcro wrapped around the seat belt and roll bar.
Ford Bronco Rear seatbelts flapping with top off -- how to fix? 20240222_170601
Cameront9
Cameron
Northern Virginia
BLTom
Tom
Temecula
'21 Bronco
2 dr, I don't use the back seat. I used cable ties
j_anderson
Fort Wayne, IN
www.instagram.com
