Any Tips for Removing rear Seatbelts 2 door?
telenerd
Laramie
Subaru
Howdy,
I did a seat delete on my 2 door. Now I would like to remove the seat belts so they aren’t flapping around. Any tips would be appreciated. Didn’t want to go in without a plan. I was thinking about tucking them into the plastic enclosure by roll bar.
Thanks
MileHighCitizen
Al
Denver
Bronco 2D 2.7
i just unbolted them from the floor, rolled them up and used a small bungee cord to tie it to the roll-bar under the speaker. DOn't even notice them and they don't make any noise in the wind or anything.
It's a torx bolt, and that way they can be reinstalled easily.
telenerd
telenerd
Laramie
Subaru
Thanks. I was thinking about that but want them a bit more hidden. Not sure how those plastic panels come off and don’t wanna damage anything.
MileHighCitizen
Al
Denver
Bronco 2D 2.7
In that case, check out the Instruction for installing the tow-kit wiring, it shows how to remove the panels on the driver side, and the instructions for installing the factory subwoofer will show instructions for the passenger side if it's not the same.
tbh, I didn't even notice them once they were rolled up though, but you do you.
KRAKEN
Andy
North Alabama
2023 2 DOOR BRONCO, 2014 F150 XLT, 2006 F150 FX4
I unbolted mine and tucked them in the panel by the roll bar without removing the panel. You have to just feed them in the gap. Don't think the gap is large enough to get them in there if you bundle them.
telenerd
telenerd
Laramie
Subaru
I ended up saying screw it and just took the torx bolts out and cut the belts out with scissors. Didn’t want to dink with removing the panels or have the belts make noise inside the panels going down a fire road.
I have zero plans to reinstall the rear seats ever! The rear seats will remain in my storage basement till I’m old and grey.
Now deciding what to do to finish floor.
TLO
E
Canada
youtube.com
2 door Squatched
Removing the side panels is super easy...
Removing the belt spools requires a resister to be added to the harness so you don't get a MIL
