Removing Rear Crossbar Cover?
Num Num
Kirk
Norman Ok
Toyota....
So the question is this:
2023 Wildtrack, rear crossbar where the speakers and light are mounted. How does that cover come off?
At highway speeds there is a rattle type noise, when I tap it it seems to be tapping the "roll" bar. I tried the little felt pads but that didn't seem to get the noise stopped. I would like to get that cover off and put some more felt or something in there to get the rattle stopped. I hope maybe someone has had that cover off and will prevent me from breaking anything.
bldavis11
'23 Badlands
Did you ever figure this out? I need to take that trim piece off as well. Ultimately, It looks like the trim panel under the rear seat belts needs to come out.
Num Num
Num Num
Kirk
Norman Ok
Toyota....
I have not tried to just ad more power. I didn’t want to break anything. I put some of the felt pads along the edge and it seems to help but seem to have an air leak or rattle at around 70 mph and haven’t taken the top off to check the seals. Maybe I’ll get bold and pull a little harder and see what gives.
da_jokker
Jeep Wrangler JKUR
Mabett sells a dome light replacement. As part of various installation videos, you'll see people partially take this down. You might want to check those out.
Num Num
Num Num
Kirk
Norman Ok
Toyota....
I will give that a looks thanks. Those little plastic pieces seem to break pretty easily.
