Rear Passenger Side Wind Noise
hkhyman
Hattie
Florence SC
2025 Ford Bronco Outer Banks, 2008 Ford Mustang Premium
Well please report back if they figure anything out! Like I said I have the soft top anyways so I'm not too worried about it but would like to at least know why it started.
Still no resolution - my dealer always seems to be "short staffed" or someone called in sick so they never get to address half the things I bring it in for. I'll have to bring it back in for some paint work eventually - I have paint chipping internally on the roll bars...never seen anything like this before. It almost looks like the steel under the paint is irregular or pitting and causing the paint to chip off - anyway, they will probably have it a while whenever I manage to get that scheduled so maybe I can get them to look at the seals again then. Not holding my breath, though. Seems like with so many people having this same problem on the soft and hard tops, I almost think it's an aerodynamic issue? like something about the shape of the truck is causing wind currents to concentrate in this one specific area or something.
FlyingBronco3
Tyler
My 2 door hardtop has the noise as well. I just turn the volume up louder :LOL:
Fastmc25
Fastmc25
East Tennessee
24 Big Bend
Duct tape that sucker closed. šŸ˜‚
two most important things to have. Duct tape and a coat hanger. šŸ‘šŸ˜ŽšŸ˜‚
BRBlue
Houston
Toyota Tundra
This was a pretty easy fix for me. Just needed to adjust the tilt in at the top of the window. There are two bolts for this adjustment that can be accessed from the bottom of the door. I could see that one of the bolts slipped from the initial factory setting. I moved it back and tightened and the noise is way better now.
Here’s a link to the service manuals with full instructions. You may need to adjust additional bolts to get the windows within spec. No need to remove the door trim panel if you only need to adjust the tilt in.
https://www.bronco6g.com/forum/threads/window-getting-caught-when-opening-door.24948/post-1172539
DJ Vinny
Vincent
Westerly, RI
Same issue here. sounds like a window slightly open. no water leaks tho. passenger rear 2025 badlands painted hard top SAS
RKT SHP
Kentucky
2024 Badlands, 2012 Cadillac CTS-V, Etc
I have the exact same issue and vehicle. Just a 2024
BRBlue
Houston
Toyota Tundra
I have a 2021 with 70k miles and I suspect all of the windows will eventually need to be adjusted as the seals relax and/or the window guides and adjustment bolts loosen. The joy of owning a convertible. I fixed the rear driver side window but now I’m noticing the other windows are much noisier then before.
Start by cleaning and treating the seals with silicon spray or Gummi Pflege or similar. If that doesn’t help then you will likely need to make some adjustments as noted in my post above. I would start with the tilt in adjustment which can be done from the bottom of the door without removing the interior door panel.
RKT SHP
Kentucky
Yeah, I tried the adjustment on the bottom (really simple actually) and it made zero difference. I think it might be time for a trip to the dealership.
DJ Vinny
Vincent
Westerly, RI
way too complicated for my patience and time. level. i wonder if dealer will do it under warranty.
VirginiaHeritage
Frank
ā€˜25 Bronco HE
šŸ‘€ same issue on a hard top. Same window.
Wind noise, loose latches, window glitches. I’m telling you, that seat is cursed in all Broncos.
