Rattle engine/exhaust rattle
Brockdog12
NTX
2022 Explorer ST-Line
I had a rattle sound on acceleration when cold after I bought mine last February, then some transmission issues. Dealer was able to take care of the transmission issue and I also notice the rattle noise was pretty much gone too. Hmm... However, now that it is "cooling" off outside, I am noticing a slight rattle sound on acceleration again in the mornings. My OBX is garaged also.
PrincipalD
Ryan
Sioux City, IA
Expedition, Bronco
I have the same thing happening in my 22 OBX. It’s completely just a sound and have had no performance issues. When I first searched for it I saw stuff about CAM Phasers… nothing about it until I saw this one.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Hi, the catch can bolt has been good and tight, have not had to tighten it, though I did put some blue loctite on it when I first installed it.
I completely forgot about the catch can when I brought it in for an oil change. They didn't say anything, either didn't see it or didn't care.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Sparkherd
Sparky
South Central Texas
www.sparkherd.com
Lifelong Ford guy.
I consider it normal, I guess. I think general consensus is that these direct injected ecoboosts are noisy. It runs fine, no issues, getting about 22mpg (2.3L, 7mt, 6500mi), .
I have the extended warranty, hope I'll never have to use it.
Doesn't sound right to me.
Only ecoboot I've got ownership experience with is my 2014 FieSTa with 49K miles and the 1.6L.
The stoopid blend door actuator (dumb idea Ford!!!) makes more noise than that.
GIBhood
GIBhood
Indiana
64 f100 and 2000 VW Jetta and ordered my bronco
I dropped off my 22 Bronco at the dealer today. I let you all know what they tell me.
RyanRallyX
04 Tacoma, '12 Pilot, '21 Bronco
Grabbed a quick video of the sound. There's also a metallic hum or vibration you can hear "under" the loud DI ticking.
Mine is like that also, figure it is normal. Good otherwise.
Tacanta14
Wasichu
Pie Town, NM
2022 Black Diamond 4 Door 2.3 MT
I forgot about Loctite (I'm old and brain damaged), and the red, as i remember, is forever, so blue Loctite it is!
I can't imagine that they didn't see the catch can, so maybe the mechanic didn't want to hassle you, so lucky for you!
GIBhood
GIBhood
Indiana
Update!
I picked up my Bronco today and was told the noise is normal. it is coming from the secondary high pressure fuel pump. They even sent me a video showing me exactly where the noise was coming from.
I’m happy it was nothing.
BroccoliBronc
Pennsylvania
2022 Bronco black diamond manual, 2020 Fiat spider
Thanks for the update. I'm leaning towards that as well. I do have a distinct metallic hum under the Bronco that I believe is exhaust related but if the rattle is normal I'll live with it lol.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
They wont hassle you until theres a warranty issue. Prolly noted already
droosif
Drew
Rochester, NY
Forester
Hello is this the noise y’all are hearing? This is inside and outside the vehicle on driver side of engine bay. Even after engine is warm I’ll hit the accelerator and this thing kicks on then quiets back down.
2.3L 2 door base auto trans
Runzdawg
Rich
Ohio
Enclave
I had the same rattle on acceleration when cold. Took my to the dealer and they indicated they heard nothing? Not sure what they did, but obviously they didn't accerate with much of an increase in rpm to check thebissue. Issue still exists. Sounds awful when cold for a new vehicle at this price point
Mustangsvo86
Chad
2007 F150, 2018 Edge, 2003 ZX2, 1986 Mustang SVO
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
I’ve got the same issue. Delivered on Jan 24. Build date is Dec 6. 2.3 auto.
JadeMyWorld
Upstate NY
2024 Outer Banks Sasquatsh 2.3l
Do we Know the source of that humming noise? I started hearing it yesterday but not in every cold start. The hum disappears after the rpm drops from 1200 to 900 rpm.
