Raptor 17" Wheel Offset That Works NO PROBLEM
MDrums
Tampa
Bronco Raptor
I want new wheels for my 2026 Bronco Raptor. I have an oem stock gloss black cast wheel. Decided on Method and probably 709HD with the removable rash ring.
The Method 709 17x8.5 can be ordered as et0 offset or et25 offset. The 709HD also has the correct hub size so the wheel is hub centric. I see some here doing 0 offset but that is a big deviation over stock suspension geometry. I do not want to rub and knock off a fender and I do not want to change the stock Bronco Raptor suspension. Pushing wheels out as far as 0 offset I worry about causing damage.
I also have a line on the Raptor headlock capable wheels that are an option on our Raptors for $800 new take off 10 miles on them. I like these wheels looks too and the price but I hear they are very heavy.
Ford Bronco Raptor 17" Wheel Offset That Works NO PROBLEM Screenshot 2026-07-15 at 3.10.42 PM
Ford Bronco Raptor 17" Wheel Offset That Works NO PROBLEM Screenshot 2026-07-15 at 5.23.30 PM
Ford Bronco Raptor 17" Wheel Offset That Works NO PROBLEM Screenshot 2026-07-15 at 5.20.50 PM
Ford Bronco Raptor 17" Wheel Offset That Works NO PROBLEM Screenshot 2026-07-15 at 5.24.45 PM
swamp2
Zero offset is often used here by forum folks with no damage and no rub. I run it too.
Spooled
Republic of Texas
Raptor, Model 3
You'll be fine with 0. I have spacers on the stock wheels which is pushes the wheel out close to what 0 offset would be. I wheel mine hard. No issues.
MGF
CA
Bronco Raptor, Merc AMG C63S, Range Rover Sport PHEV, BMW 328i
I run +0 offset wheels with true 37” Falken AT4Ws. Zero problems.
Squatched
Wil
Maryland
89 Ford Bronco
What size spacers did you use? Do you have a link for them? Thanks
Spooled
Republic of Texas
Raptor, Model 3
