Quick Oil Priming Video
Car Guy Bill
Bill
Homer Georgia
25 Marsh Grey Badlands Sasquatch HOSS 3.0- 2025 Mach e GT Performance Upgrade
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
The engine doesn't differentiate between the starter rotating the oil pump, or the combustion cycle.
Car Guy Bill
Car Guy Bill
Bill
Homer Georgia
Spinning the engine via the starter motor avoids turbo spool-up because there is no combustion. Furthermore, the absence of a combustion cycle greatly minimizes the load on the crank and rod bearings
Ducati1098
Crank, rod, cam, turbo bearings.. none of that is dry after an oil change.
Simply starting the engine after an oil change is absolutely no different than cold starting it in the morning after the engine has been off for hours.
Do people that use this also “prime” their engine every morning? I’m honestly curious.
Just starting the engine will build not only more oil pressure, but also much quicker than clear flood mode.
If there was any validity that this somehow helped or caused less damage, it wouldn’t be called clear flood mode. It would be called engine oil prime mode or something, but that’s not what it was programmed for.
McRightclick
Idaho
2026 Badlands 2DR 7MT
After an oil change the filter is empty and it takes a few extra seconds to fill with oil before pressure can build; over on BITOG some folks logged their oil pressure readouts on startups and there is a noticeable delay in time to get to full oil pressure between a normal start and an empty filter. I think there was also an LSJr video on the topic with some pressure traces too.
Probably not going to hurt anything if you don't use it, but I would for peace of mind.
BillyB
Billy
Park City, UT
Does your FD use this alt to re-start after an oil change...I asked mine after Apr 2026 change and the response was...whaaaaattt ???
Ducati1098
There’s still residual oil on everything. Whether the filter is dry or not.
There’s probably millions of oil changes done every day without “priming” the oil and yet never any issues, that’s all I’m saying.
HotdogThud
mk6 gti, '21 MoarDoor
This is completely unnecessary for oil changes. But if it makes people feel all warm and fuzzy doing it, more power to you 🤷‍♂️
Indeed. Better advice would be to let the engine 'rest' for about 30 seconds before shutting it off if you've been running it hard or it's particularly hot out, to cycle cooler oil into the turbo and prevent coking.
Umichigan1
2022 2-Door Bronco
No, no, no! This priming idea is totally legit. Everyday I do this as I prepare to go to work in my 1918 Model T (its black and the T stands for turbo). I expect to get another hundred years out of this baby!
BillyB
Billy
Park City, UT
Let's agree to disagree here...or not. Choose your side...Boris the Animal or Agent J ???
MilesTeg
United States
2024 2DR Badlands Manual/VB, 2018 F-150 Lariat/3.5EB, 2013 Mustang GT DIB
Neither this nor filling the oil filter matter -- probably. But, it's trivial to do one or the other, so I do it.
