- Jun 21, 2022
- 23
- 539
- 683
- Horicon Wisconsin
- 2012 F-150 Raptor
- Raptor
I can't imagine mobile 1 or any other quality full synthetic carbonizing like that.
This. had a mechanical failure in my VW at 150k miles (timing chain tensioner failure) and for a car that had 150k, and did 15+ track days in its life, with 7500 mile interval oil changes, this is what the top end looked like when I pulled it all apart:I go by the factory recommendations and run full synthetic in all vehicles. Honestly, oil-related breakdowns are pretty rare for engines with under 150-200k miles, it's usually something else that does them in before that.
Agreed. There's more in the video that seems to point to a lack of other proper maintenance rather than an "extended" oil change interval. For example, he mentions oil feed filters for the turbos being clogged. I can't imagine that those filters don't have some kind of cleaning/replacement schedule that was surely missed long before 200K+ miles. Heck, he even specifically mentioned that one turbo was replaced without changing the filter and it failed soon after. So it would seem the dirty filter was the problem.I just skimmed through the video, didn't he say the engine has 240k or 220k miles on it? That's about what I'm looking to get. Plus I also thought he mentioned the owner waited for the intelligent sensor to tell him when to change it. Did he mention what oil was used? Normal or synthetic? There seem to be quite a few variables that aren't being nailed down.
Personally, I'm running full synthetic and changing every 8k miles. As @Imaginary Friend stated, yes oil is relatively cheap.
So why go 8k miles? Being I put on approx. 25k miles per year, I'm opting to change about 3 times/year vs. 5 times. Call me lazy or whatever, I don't care, my truck, my maintenance schedule. All I'm saying is, the video doesn't give enough information to state much more than "Don't wait for the truck to tell you when to change your oil". Which seems rather obvious.
I'll disagree on this one point. No auto manufacturer can survive today with this business model. If oil changes alone would solve engine problems and reliability issues, wouldn't it make sense for any manufacturer to simply reccommend more frequent oil changes? Of all the costs to maintain a vehicle, the oil change is one of the least consequential, even if necessary every 5,000 instead of 10,000 miles. Ford's goal is most likely to be as competitive with industry average or better in reliability in the least expensive way possible. Oil changes cost Ford nothing.A couple things to keep in mind:
- Ford's goal is to get your engine through the warranty period. After that they do. not. care.
You're going to get different answers on this, and a lot of older people believe the calendar matters. It doesn't. On a modern engine with modern oil, you don't see issues with oil simply because time has passed. In fact, the calendar part of the oil change recommendation was creating not because oil needed to be changed after a specific time period, but to make it easier for customers to remember when it was time to change. It was thought that it would be easier to remember January, April, July and October rather than 18, 21, 24, 27K miles. (Oil change intervals used to be every 3K miles.)What about time between oil changes? Frankly my household is not driving all that much the past few years. Is the 6 month change rule of thumb valid, when you are not driving more than a few thousand miles (if that) during that time period?
For every single component in a vehicle, a design life is chosen - years, miles, rotations, power cycles. The component and manufacturing process are designed so that 99.999% of components make it to that lifespan. This isn't done accidentally, haphazardly, or by any amount of chance. They do not just overbuild it and hope for the best.I'll disagree on this one point. No auto manufacturer can survive today with this business model.
In the first 60,000 miles, you're probably more likely to incur damage due to a ham-fisted tech messing up an oil change than you are running the same oil for 10,000 instead of 5,000 miles. I'd say frequent oil changes are a HIGHER risk if you're taking it to a shop.If oil changes alone would solve engine problems and reliability issues, wouldn't it make sense for any manufacturer to simply reccommend more frequent oil changes? Of all the costs to maintain a vehicle, the oil change is one of the least consequential, even if necessary every 5,000 instead of 10,000 miles.
What's "reliability?" Most places only track reliability through the first five years. What metrics out there track reliability further than that, and also publish results in a way that affects the public's buying decisions?Ford's goal is most likely to be as competitive with industry average or better in reliability in the least expensive way possible.
Now you're bumping into my second point - lower cost of ownership matters.Oil changes cost Ford nothing.
Truth.You're going to get different answers on this, and a lot of older people believe the calendar matters. It doesn't. On a modern engine with modern oil, you don't see issues with oil simply because time has passed. In fact, the calendar part of the oil change recommendation was creating not because oil needed to be changed after a specific time period, but to make it easier for customers to remember when it was time to change. It was thought that it would be easier to remember January, April, July and October rather than 18, 21, 24, 27K miles. (Oil change intervals used to be every 3K miles.)
How many miles a year are your vehicles accumulating?
On my Wife's F-150, the oil monitor will go off in one year even if she is well under the 8000-12000 usage miles. I think all Fords do that.You're going to get different answers on this, and a lot of older people believe the calendar matters. It doesn't.
Agree, 100%!People overthink oil like no other automotive topic....
