Proper sequence for 5 tire rotation
KRAKEN
Andy
North Alabama
2023 2 DOOR BRONCO, 2014 F150 XLT, 2006 F150 FX4
What is the procedure for doing a five tire rotation?
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
this is what I do
Been doing this one every 5000 miles for over 20 years... And I get great wear out of tires that people can't get to wear right.
Not a single feather in sight. ;)
Ford Bronco Proper sequence for 5 tire rotation tire wear
userdude
Denton, TX
2023 2dr Badsquatch
Obvious question, but why is there a "proper sequence" to rotating a tire outside of clockwise or counter-clockwise? Figure there's a reason, just want to know what.
JT58Bronc
JT
Fl
I do the 5 tire rotation per the lower pictures as well. I do it every 2500 miles, which is only 2X a year in my case. I prefer the lower picture rotation as putting the spare on the front I'd be worried about different diameters and steering wheel being off center.
scotman623
Saratoga Springs NY
Chevy LT Trail boss
All of the above will get the job done, this is the one I have used on my last 3 Jeeps and now my Bronco.
Ford Bronco Proper sequence for 5 tire rotation IMG_4780
KRAKEN
KRAKEN
Andy
North Alabama
Thanks guys!!!!!!!!!!!!!!!
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Like many things, it shouldn't matter so long as you do it the same way each time. So if you do them yourself just follow the same pattern...but since most people take their vehicles somewhere like a Discount Tire or the dealership a "right way" has to be established so that they are consistent as possible.
Moto26
Tucson AZ
Here's my cheat sheet. I also include torque values and socket size so I don't have to spend a lot of time on it each time I rotate...
Ford Bronco Proper sequence for 5 tire rotation IMG_8857
vzqhsg
MI
F-150, Badlands
How many miles do you get on a set doing a 5 tire rotate?
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
Too many variables to answer that. Start with the tire you choose, some give more mileage than others. Then there's the air pressure you opt for, driving style, type and amount of off-roading you do, and lots of other things. The issue should be that you do it regularly & consistently, maintaining alignment and are alert to repairing road damage, proper inflation, and watch for inconsistent wear.
ChrisB351
Shreveport, LA
If you look in the owners manual this is how Ford says to do it.
kodiakisland
Arkansas
Exactly. Same way every time. Some on here want to argue your spare HAS to go to a specific spot. It doesn't, but it does need to go to the same spot each time.
kodiakisland
Arkansas
20% more miles than the same set would have gotten only rotating 4.
