- First Name
- Chris
- Joined
- Nov 4, 2024
- Threads
- 28
- Messages
- 1,489
- Reaction score
- 2,430
- Location
- Southern New Mexico
- Vehicle(s)
- 2016 Sequoia, 2012 Tundra, 2024 Sasquatched 2.3L 7M 4Door Bronco
- Your Bronco Model
- Big Bend
Well now I’m not exactly sure what you’re looking at. It’s battery post (granted a little extension), BMS (black plastic box) sitting on top of said little extension, and then on top of BMS the tab and the rest of the Bronco.I didn’t say that….BMS tab is on battery post side then to the sensor then outgoing wires. If tab was on wire side coming out of BMS then yes it would make sense. I’m not trying to argue with anybody on here I’m just not seeing BMS between tab and battery post. Post and tab are both on same side of BMS
For the BMS to measure current has to flow through it…
