Power-Up 6.1.0
fiatlux
CA
Volvo V60 T8 Polestar Engineered
Opened the Fordpass app this morning and saw that there’s a new update available. Anyone know what’s included? All it says is “Minor Adjustments”. Thanks Ford, real descriptive.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
Wow. I'm still stuck on 4.2.4. Hasn't updated since October 2023. :cautious:
fiatlux
CA
That’s what I was on too. Mine has said 4.3.1 was not completed for the past 6 months too
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I’m still showing my last update as September 2023 - 4.2.2! :cautious:
I know there’s some tips and tricks to “force” an OTA software update, but curious if anyone has tried some of them, and what worked for them (if any)?
adamruiz2001
SoCal
Ford SVT Lightning
I cut the cord last Sept - still holdout w 4.2.2 and no problems whatsoever
Think I'm done w Ford's update mess
I have the same 4.2.2 but just recently realized a few weeks ago that my Alexa or the voice button on my seeing wheel isn't working. So annoyed when things don't work the way they are suppose to.
adamruiz2001
SoCal
Ford SVT Lightning
I'm still stuck on 4.2.2 from last March, but I realized my Wi-Fi was somehow turned off. I saw that Wi-Fi has to be turned on and signed in, in order for the updates to happen, might check your settings on your Bronco.
604Bronco
British Columbia
www.bronco6g.com
Thanks - I’ll check that out.
Did you just notice that and fix it, or was it a while ago? Did you see an update come through afterwords?
adamruiz2001
SoCal
Ford SVT Lightning
I have been wondering why I haven't had an update for so long and keep seeing others on here getting updates. So I dug through the Ford pass app to see if there was any info on updates and saw it said something about the Wi-Fi needing to be enabled for updates to happen. So I literally just realized my Wi-Fi was disabled some how. Now I will see if anything comes through, my normal update schedule was set for Sundays at 12am.
604Bronco
British Columbia
www.bronco6g.com
Looks like my wifi was “on” in my Bronco, but the network it was tied to initially was not anymore. I wonder if it has something to do with when a power outage occured at our house or something.
Anyways, I re-attached it to our network, and will see what happens. I think most OTA updates occur whether you’re on wifi or not, so I’m not sure if this will do anything or not. No harm in trying though!
adamruiz2001
SoCal
Ford SVT Lightning
Yeah, I think your right, it doesn't necessarily need Wi-Fi, but says it does help with downloading updates faster. Fingers crossed 🍻
Ducati1098
Damn we just got spanked guys and gals:
Ford Bronco Power-Up 6.1.0 1711819489728-xy
For a brief moment I was crazy excited:
Ford Bronco Power-Up 6.1.0 1711819576213-fr
But down below it then says it's for Mach-E only.
I did find these lists:
Powerup 4 & 5:
Ford Bronco Power-Up 6.1.0 1711819692753-jd
Powerup 6:
Ford Bronco Power-Up 6.1.0 1711819724317-gl
Mr Bacon Jr
Gary
Santa Fe, NM
Yeti SB130
At least I am not the only one whose WiFi got turned off mysteriously. Vehicle says update 6.1.0 is the latest applied, FordPass Messages says 4.2.3. But FordPass "Software Updates" says 4.2.11.
adamruiz2001
SoCal
Ford SVT Lightning
I finally got a update to 4.2.3! Hopefully 6.1.0 isn't to far behind. My steering wheel button for the Voice Nav and the Alexa is still MIA 🤷‍♂️
Brouha
Nick
Chicago
I have toggled on the WiFi setting on my bronco at least a dozen times. Never stays set at ON and I gave up trying. I eventually get the updates though.
