Plug welds missing on axle tube
Baja_bronco
Andrew
Hemet ca
2022 bronco wildtrak, 1996 bronco
So we did some wheeling yesterday and this morning noticed gear oil from the rear end. Well on a creeper with a flashlight I noticed one of the plug welds are missing on the axel tube. How does one explain this???
Ford Bronco Plug welds missing on axle tube BDF55EC0-C63F-4F00-ACD0-D1DC230842EF
swooshdave
Portland, Oregon
Mustang
I'm sure @Ford Motor Company will be along tomorrow to ask for your VIN...
No way to hit anything there. Is it threaded?
BigMeatsBronco
Allan
2021 FE 2 door
trail turn assist does this...the forces from one brake being locked up, and the other side unlocked, combine with the forces that want to cause axle wrap or pinion lift (twist) are too much for Dana spicers housing, this has happened to others as well and IMHO will continue to happen to others broncos in the future.
I predicted this would happened when I first read about trail turn assist before the Bronco was even released.
And I also suspect the spider gears get EXTREEM pressure and even deflection during TTA events.
in the OPs case the tube is twisting inside the cast iron center section., and likely sheared off the welds.
I've done this before on other vehicles when one axle housing mount was loose. the tube rotated inside the housing...it's an a fairly common thing.
my solution was to weld all the way around the joint.
2023bronco
location
vehicles
Cast iron to steel. I had it done on my Chevelle's 12 bolt. I think nickel rod is the preferred method. Or tig N99.
swooshdave
Portland, Oregon
Mustang
Has it been reported on the forum before?
Baja_bronco
Baja_bronco
Andrew
Hemet ca
So after further research it spun the axle tube. Two other have had the same issue.
[/QUOTE
Did some jackwad drill it out? I don't see how a weld pops out and there's a little sliver.
the axel tube spun.
thesocalexplorer
Southern California
UPDATE!!!!
The dealer is saying they won’t cover it because I took it off-road. This is gonna turn into a shit show.
Wow, that's absolute BS. Which dealer?
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
UPDATE!!!!
If they cover swamped alternators they will cover this. Dealer is trying to get out of it. Try somebody else if possible
Ducati1098
UPDATE!!!!
Show them this and contact Ford. Unless they can clearly prove abuse, this should be a warrantable concern. Off-roading alone does not void your warranty.
Ford Bronco Plug welds missing on axle tube D617767F-5EFA-4E56-B840-076D2513B423
