helifino16
Ron
Mount Sinai, NY (Long Island)
Wow - nice!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
I put this in my KRAKEN build thread, but thought I would post here as well for more visibilty.
Painted KRAKEN's roll bar with Plasti Dip; color "black & blue". Was planning to wrap the roll bar, but after a close inspection of the roll bar's many welds, spot welds, holes, & slots I decided to just Plasti Dip it. Was going to do it black and then I found the black & blue color which plays well with my stripes & rockers. I removed the roof latch plates, speakers, and window molle brackets and installed temporary screws in all the threaded holes. I did not remove any plastic panels and just taped & draped everything which was a big pain in the @ss, but I got it done. I used two cans of Plasti Dip and got 4 good coats with a little left for touch up. Wish I had another can for a couple more coats. If you do this, plan on needing three cans.
Before & After:
Looks amazing! Thanks for sharing!
BigCatISU
Raleigh, NC
2022 F150 Tremor
Before & After:
Looks great!! Was thinking of doing the same on my 2 door. When I talked with the Plasti Dip team, they said the spray cans wouldn't do well on horizontal surfaces because of the cans spitting clumps. Did you have any issues like that?
drewski
Greenville
2018 Ford Mustang, 2007 Toyota Tundra
Nice. Glad you posted this and are happy with it. I am wanting to change the color of my hard top and thought about plasti dipping it. Of course i won’t use spray cans to accomplish that. I don’t see much on here about ppl using plasti dip.
KRAKEN
KRAKEN
Andy
North Alabama
2023 2 DOOR BRONCO, 2014 F150 XLT, 2006 F150 FX4
I Plasti Dipped my Sas Beauty Rings and it has held up very good, so far. That helped my decision to use it on the roll bar. No problems with the spray clumping as long as you keep the can somewhat vertical which you can do for most of the roll bar and just spray at an angle to the horizontal top of the bar. You can get a couple of good short squirts in a more horizontal orientation before the feed tube inside the can empties. Just squirt, squirt, then go back to vertical. Be sure to shake the can good before using each time between coats and shake a little during use.
nolimits
23 Badlands
Just curious but are there other colors of plastidip?
My Badlands is iconic silver and I’m thinking of going the inverse on the roll bars and use them as a highlight color. Really like this setup below with the bright green but also considered a bright red.
Side note: would like a custom cage too but haven’t saw any on Broncos yet.
Ford Bronco Plasti Dipped my Roll Bar IMG_0885
  • Like
Reactions: Dom
tilebroncodude
Derrick
Philly burbs, Pa
24 Big bend 7M, 21 f150 lariat
Before & After:
i noticed you keep your thumb screws in the car, you dont worry someone will take them?
KRAKEN
KRAKEN
Andy
North Alabama
I actually run these window molle panels which makes them less accessible, except for the back ones. Also have a bunch of molle bags on my cargo molle panels full of bungee cords, rope, paracord, zip ties, rain gear, flashlights, toilet paper, etc. If someone steals shit, of course I would be pissed, but it will get chalked up to the price of running topless I guess. After all freedom isn't free.
Ford Bronco Plasti Dipped my Roll Bar 20240621_135048
jorgem31
Jorge
Tampa
Wonder how one of those retro builds would look with that bar wrapped in chrome.
Agrod
SJ, PR
22 4dr OBX
I just found that there's a roll bar cloth cover, similar to what older Jeeps have from the factory. The only "bad" thing is that it doesn't cover up the front part of the roll bar (because of the side curtain airbags, I suppose). It's a nice option for those wanting to protect the roll bar paint with a less permanent solution.
Ford Bronco Plasti Dipped my Roll Bar 1719257643044-bx
