Phone Mount Recommendations
Ducati1098
Ducati1098
Yeah I don't understand that. Like mentioned, I've had this exact phone mount and magsafe charging head for years now 🤷‍♂️ maybe that one is newer and they changed something?
Ford Bronco Phone Mount Recommendations IMG_8275
Stevenson James
Chicago
2024 Bronco
If I had to guess, theyre probably sourcing that specific head elsewhere, but they dont reply to messages so it leaves me a little weary of purchasing from them. Like if you can't reply to an email, can i trust youll actually fulfill my order?
kahunabob
Bob
Santa Clarita, CA
4runner
are you using the knockoff? Are there magsafe charging heads available that will work with it (whatever the ball mount size is)?
I am using the tackform dashboard mount. But I am pretty sure this uses a 17mm ball (common ball size). You can get many different phone mounts (claw, clips, magnets) for a 17mm ball.
helifino16
Ron
Mount Sinai, NY (Long Island)
Maybe it's just me, but I've found the safest 'mount' for my phone is safely tucked in my pocket. If not for CarPlay, I wouldn't even take calls in the car.
Driving back and forth to work, almost every other driver I see is looking at or manipulating their phone in some manner and NY was one of the first states to ban Cell phone use while driving. Even worse is when I see a driver looking at their phone going 50MPH in traffic with a teenaged (or younger) passenger in the car. This new generation will not be able to drive safely anymore because they're SO involved in everything BUT driving.
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
Quad Lock adhesive mount with wireless charging head. Portrait or landscape with just a turn.
Ford Bronco Phone Mount Recommendations IMG_3188
Ford Bronco Phone Mount Recommendations IMG_3187
Stevenson James
Chicago
2024 Bronco
Not sure the point of these types of responses. Sure everyone is entitled to their opinion but how is that relevant?
I'm assuming the people who are looking for a mount spend a good amount of time in their broncos. I commute 1+ hours each day. I utilize wireless carplay which makes the phone very hot and uses a lot of battery. So I am looking for a mount that i can utilize to charge the phone (preferably wirelessly as well). So the mount I am looking for is not for a window or dashboard and i dont care if it's in my line of sight or not. Ideally is out of direct sunlight... because my current magsafe charger is on the dashboard and the phone will not charge when it is too hot (from wireless carplay and sunlight).
So yeah, "in my pocket" isnt exactly the mount I'm looking for.
JiuJitsuJoe
Joe
2025 Bronco Badlands⚒
cfwchoi
will
los angeles ca
23 badlands 4dr, nd miata track
I normally used coursemotorsports mounts for my cars - They are chargeable and hold strong(use them in my track miata and no issue). But for bronco I don’t like the location, so I customized it (used jb weld lol)
Ford Bronco Phone Mount Recommendations IMG_1413
Ford Bronco Phone Mount Recommendations IMG_1415
Ford Bronco Phone Mount Recommendations IMG_1474
Ford Bronco Phone Mount Recommendations IMG_1451
CalvinT
Calvin
Phoenix, AZ
Whose Magsafe charger did you use? It's the first one I've seen that has a USB C connector instead of a cable.
cfwchoi
will
los angeles ca
its coursemotorsports head. i took it out from my previous vehicle. and jbwelded with amazon mount.
Antimadder
Bryan
Oregon
Personally, I can't stand a phone in my face or in a vent while I'm driving.
My first mount solution was this...
Etsy: Ford Bronco MagSafe Phone Mount (2021-2026) | Console Swivel Holder.
Amazon: Adhesive metal ring, wireless charging puck, Benks case for iPhone 16 Pro.
1. attach adhesive metal ring to the back of the Wireless puck
2. attach wireless charging puck to magnetic mount head
3. plug in wireless charging puck to USB port
4. Attach phone with magnetic capable case
Ford Bronco Phone Mount Recommendations mount
I was really happy with it, still am, but it occasionally interfered with some buttons and cup holder.
So, I decided to just use a magnetic charging pad in the phone holder compartment next to USB ports. I had to add some gorilla tape underneath rubber tray pad, and additional gorilla tape to keep the charging pad in place.
https://www.amazon.com/dp/B0DRP1TZ3X?ref_=pe_125775000_1044873430_t_fed_asin_title
This is my current and preferred method
Ford Bronco Phone Mount Recommendations pad2
