Performance Clutch Upgrade
NJRoadkill
South Jersey
www.instagram.com
22 Bronco Badlands 2.3l Manual
Any companies developing a performance clutch upgrade for the M7?
Monster comes to mind, had them in other cars,
Long term I’m going to end up smoking it. I’ve already smelled it in a few situations. That $3k smell 👃 😂
Oldhippie
Barry
Santa Cruz, Calif.
My guess is a mustang clutch would be the same??
Ducati1098
Not sure this is something worth making. I feel like the stock clutch should easily be able to hold any power you have. Even with a tuner, you aren’t that far above stock numbers to need a “performance” clutch.
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
Thanks! Call it what you want, HD clutch. If I’m smelling it under certain load circumstances (yes driver input/error is a consideration for sure) then it’s likely a part that could use heavier springs for example. Or a better material for the pressure plate. Etc...
Just curious. I know it’s only a matter of time before the clutch will need to be replaced and I’m using mine under heavy load constantly which only shortens life span. Not something I would ever expect Ford to cover under warranty even under optimum use.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
GI_Jo_Nathan
Jonathan
I think the Bronkbuster guys were testing one a while back.
Lèòn
Jersey
Heard someone was developing one. Cant say ill burn mine up soon, but a bit less newbie friendly and a pinch more firm and precise would be nice
Lèòn
Jersey
Hopefully centerforce comes out with something
Ditto. I still want something Daily and city friendly, but I don't need something beginner level either
Lèòn
Jersey
Also, will they release a new flywheel, and will it be heavier or lighter?
Lèòn
Jersey
@lethaljake , any word about clutches and flywheels?
Lèòn
Jersey
Nothing that I have heard of, personally!
All good, heard Downpipes should be in the works for the 2.3 in Jan btw, or the beginning of next year
