Paint vs Powder Coat
King_bronco
Madison
Tulsa
2018 f150 with a 2022 bronco ordered
I’m looking into purchasing aftermarket bumpers. Trying to take all factors into consideration like cost and durability of paint vs powder coat. I am just looking to have them in factory Oxford white and want my whites to match but not something easy to get rock chips.
Thank you!
Lak34ers
Troy
Seattle
Thank you!
You can also do thermoplastic powdercoating which is what BAMF uses. Scratch or chip you just use a heat gun and plastic powder and it is good as new. Pretty cool stuff.
Cux211
NE PA
19 ram 2500 Laramie blackout cummins
Powder will be way more durable but you probably won’t get a perfect color match
HoosierDaddy
__ Eric
NW. Indiana
Not a painter, but from my research ....
(If a pro is reading along, please set me straight.)
PVC (powder coating) is all the rage, but I'm not sold on it.
Powder coating is generally considered to be more durable than a paint ... until it is damaged.
Once it gets chipped, the seal has been opened, moisture will get in there and start wreaking havoc. Once the rust starts, it will run-a-way under the powder coating and cause it to lift and peel off.
Generally considered impossible to repair/ touch up. There is essentially no touching it up and having it match worth a damn.
You can see the run-away rust happen on numerous aftermarket skids and bumpers pictured on this site.
About as close as you 'll get to the durability of pvc, and this will be very close,
is an epoxy primer over a coarsely sand blasted surface, which gives the epoxy something to bond with.
It is easily repairable and run-a-way rust issues won't be a problem.
Of course, after the primer you color coat with the color of your choice. A quality polyurethane will probably be the best bet, vary durable as far as paints go, but again, not a painter/ coatings pro, there may be newer or better stuff out there.
Karl_in_Chicago
Karl
Chicago
Given the number of skid plates in the wild I realize I've only ever seen a very tiny portion of them as a percentage but . . . I've never seen powder coated skid plates (and can't imagine why anyone that would use/need a skid would PC it). Who is offering PC skids - or are you seeing people getting their skids PC'd after the purchase? Either way I find that quite odd.
King_bronco
Madison
Tulsa
Need ford oxford white
DV8 skids all come black PC
Karl_in_Chicago
Karl
Chicago
Huh, so they do. Doesn't seem like they offer much in the way of real undercarriage skids, just fancy covers for more visible bits with "look at me" logos cut into them. Besides DV8 who else is doing this?
King_bronco
Madison
Tulsa
I don’t know you asked I showed one right away. Sorry you didn’t like theirs.
King_bronco
Madison
Tulsa
Huh, so they do. Doesn't seem like they offer much in the way of real undercarriage skids, just fancy covers for more visible bits with "look at me" logos cut into them. Besides DV8 w is doing this?
https://backcountrybronco.com/produ...MI0ebv7qajhwMVSzUIBR1c8wfoEAQYASABEgIxP_D_BwE
IAG their skids also entire truck no look at me logos
https://iagoffroad.com/iag-rock-arm...MI0ebv7qajhwMVSzUIBR1c8wfoEAQYAyABEgJOtPD_BwE
Karl_in_Chicago
Karl
Chicago
?? I was trying to learn something, sorry it offended you (though can't imagine how/why). When someone says something like:
"You can see the run-away rust happen on numerous aftermarket skids and bumpers pictured on this site."
I figure I must have missed something as I hadn't recalled ever seeing such things on this site or elsewhere - so I asked. Lesson learned.
King_bronco
Madison
Tulsa
[/QUOTE
Not offended, you said you hadn’t seen skid plates pc. I showed pc skids and you came back about the example and then wanted another as if that wasn’t a sufficient example.
CarGuy
New Jersey
2023 Ford Bronco
Powder coating is much more durable than traditional paint.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
There are plenty of examples of the IAG steps and their rust issues. The reason why they have received the forum's attention is that they have actually stood behind their warranty and accepted warranty claims. Anyone that has purchased the white-label Amazon PC accessories have no recourse. But rest assured, even though there aren't threads on them, it is happening all the same.
One way to avoid the rust issue is to avoid the underlying steel component. Get the steps and skids in aluminum. Aluminum will still corrode once the outer PC is marred, but it is less noticeable and you won't have the run-away rust that will happen under the PC from a surface break.
I’ve found powder coat to be more durable, but paint much much easier to touch up.
Stuff that I know is going to get beat, powder coat isn’t indestructible. I think it’s fine for a bumper - you hope to not bang that around too much - but skid plates and sliders? The powder coat chips right off
