Oracle Fog Lights Fogging Problem Resolved?
CTU5000
2024 Bronco Outer Banks, 2024 BMW X3 M Sport
I'm planning to install fog lights on my '24 Bronco. I like the Oracles, but have read about fogging/condensation issues. Oracle says they have corrected the problem.
Is anyone experiencing problems with the "new and improved" Oracle fog lights?
Sgt Badlands
Midwesr
I installed mine last fall. I have had no problems so far. Been through rain, snow and ice.
CTU5000
Good to hear… Thanks for the info!
So are you pleased with the Oracles? Did you get white, yellow, or amber?
OnlyOnce
Pa
2023 Bronco
Just reach out to Oracle with the pics of the issue and original receipt. They will send you a new set. I did it and had them within a week. Only have to pay for shipping $12, was worth it.
Sgt Badlands
Midwesr
I have the Amber lights. I am happy with them. They are not overpowering. I think technically they are not suppose to be used on road. I have never had anyone flash their lights at me and I drive by a state trooper from work every night and they have never stopped me.
CTU5000
Thanks… one more question and I’ll stop bugging you:
Is the amber color pretty close to the color of the Bronco turn signals? From pictures, t
Is the amber color pretty close to the color of the Bronco turn signals? From pictures, the amber looks pretty close; the yellow not so much.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Hello, here are some details not the corrective actions taken on the Bronco fog lights. Hopefully this helps explain how we were able to significantly improve the performance of the lights.
Link to article: https://www.oraclelights.com/blogs/...y-and-performance-of-part-5890-led-fog-lights
ENHANCING THE QUALITY AND PERFORMANCE OF PART# 5890 LED FOG LIGHTS
At ORACLE Lighting we are committed to delivering the highest quality products and continuously improving our designs to ensure the best experience for our customers.
We identified an issue where, in some cases, customers reported that the LED emitters in Part# 5890 fog lights could develop a heavy fogging and droplets on the internal lens. This was caused by moisture entering the unit and condensing inside the light module.
Analysis: To recreate this phenomenon the individual modules were tested in a spray chamber and subjected to high pressure spray and vapor testing. In this testing simulation jet nozzles delivered high pressure spray from all directions simulating extreme conditions.
Ford Bronco Oracle Fog Lights Fogging Problem Resolved? spray-vapor-testing
Root Cause: In this simulation it was determined that on some units the sealant around the cable input was penetrated by the high pressure jets. The vapor that entered would then condensate and appear as fog on the lens of the light module.
Ford Bronco Oracle Fog Lights Fogging Problem Resolved? 5890_seal
Corrective Action: In order to assure that this area is fully sealed a re-design of the mold was completed in February of 2024. This revision created a chamber around the cable so that the sealant can be injected after cable assembly which would allow the sealant to completely encapsulate the opening and cable itself.
These changes ensure complete encapsulation of the opening, preventing any potential moisture entry and enhancing the long-term durability of the fog lights. With this redesign customers can expect even greater reliability and performance from our LED fog lights, even in the harshest conditions. We appreciate your trust in our products and remain dedicated to providing the best possible experience.
Visualization: Original cable Entry (1), Seal Chamber Designed to Encapsulate Cable (2), New design (3).
Ford Bronco Oracle Fog Lights Fogging Problem Resolved? 5890_updates_layout
FAQ:
Q: When did this change take place?
A: The design was updated by ORACLE Lighting in February of 2024.
Q: If I order this product, will I get the new design?
A: Yes, we only stock the new design with the updates applied.
Q: What if I have some fogging in my lens?
A: Some fogging is normal from environmental factors such as humidity and temperature differentials. These lights (as well as most modern lights) have valves in place to allow the differentials to climatize which results in fog dissipation. No further action is needed.
Q: What if I have beading of water in the light?
A: Beads of water can indicate that moisture has penetrated past the seal. In that case we can replace the module with a new unit. Please use the form located at www.oraclelights.com/rma to request a replacement.
If you have any questions or need further assistance, please don’t hesitate to contact our customer support team.
wgw
bill
Va
2023 Black Diamond Bronco
shouldn't "fog" light "fog"? lol...sorry couldn't resist
Biggin
Sean
2008 Sequoia
I am not sure I would go with Oracle . I am having issues getting my light replaced under warranty. The fogging was a known issue and should be replaced regardless of warranty status.
J-Lugster
Ancaster, Ontario
2024 Ford Bronco Wildtrak 4Dr Oxford White
Yup I agree with that.
Sgt Badlands
Midwesr
Honestly I haven’t really looked. Something I wasn’t worried about. But I like the color of the amber fogs. I don’t think you will notice if they were different.
CTU5000
OracleLights
New Orleans, LA
Don’t see a DM…
DM sent to who? I don’t see one…
Thanks for the info… appreciate it.
Wasn't for you. Sorry for the confusion.
