On board battery maintainer
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Usually add one of these to all the play toys. Just got around to the bronco. Noco 10 amp single bank with out side power point. The Noco is capable of all batteries and can do 0 volt dead. 10 amp is enough to get a starting charge in 10 minutes or so. So any inverter or generator will work out in the wild
When you park it, just plug it in. Nothing to get out or mess with. Full charge when ever you go back out.
For mine I went with a outside mount point like usual. For a stocker you could mount in the fender liner or in the sas flare it self. The unit iis on the fuse panel with all weather hook/loop
Dv8 liners with the thumb screws scored a win today. Under a minute to release and remove.
Very interesting. I don't think I could make myself cut the body though 😬
Ground_zero298
Ground_zero298
Scs michigan
These fenders are going in the trash when the new ones get here. Not in danger of messing anything up. Just need my layout for final install.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
I'm sure someone could find a use for them if you list them somewhere.
Who iz
Otis
End of the Oregon trail
F250, 4Runner, Jimmy
Correct. It’s a trickle charger also. Just plug a cord in and it works. No box to carry around. It’s always with you. Second plug end has a separate purpose coming in the future.
Appreciate the great post and the amazon link. I have been charging and maintaining the battery with a normal charger/maintainer....not so clean and safe as this install!
I will need to do similar, and run that second plug too...Please post your install as you have time.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’m tempted to do something similar for the block heater…eying the best location for the outlet.
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
NICE!!
I think you did this already—you got a lot happening near the battery so hard to tell with the photos. But just make sure you are on the other side of the BMS sensor so it knows that you are charging the battery.
I did something similar on an old F-150 and I put it on the wrong side of the BMS and it cause all kinds of weird nonsense.
I'm preparing to add a quick connect for a CTEK battery tender.
When you say "other side of the BMS sensor so it knows that you are charging the battery" you mean one of the four terminals beyond the BMS, correct?
redone17
Cold Spring, NY
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
Front bumpers are good places for power ports for chargers and block heaters. I did this on my Dodge for the block heater with a nice plug like the author used here.
[DELETED MEMBER 27901]
I just can’t understand why you think you need this. A typical agm battery is good for at least 2 years
My Bronco seems incredibly sensitive to not being driven, much more than my previous vehicles. Leave it for any longer than a week and it disables remote features and eventually won’t start at all. If OP’s Bronco is not a daily driver it makes sense.
melikebroncos
Drew
Boulder, CO
2dr Bad Sas 7MT, 911 C4S, Yukon XL Denali
Which positive terminal post did you connect the charger's positive eyelet to? Does it matter? There seems to be 4 positive terminal posts. Thanks.
Ground_zero298
Ground_zero298
Scs michigan
I ended up using the far right of the 4. It’s a m5 thread. 1-3 are m6. Should be able to grab a m5 and m6 nut from the hardware store.
redone17
Cold Spring, NY
I made some headway on this project today. I mounted my battery tender on that ledge behind the air box. It’s just zip tied in place for now. I know they make a compressor bracket for that location - but, it’s silly expensive for a piece of metal.
I routed the charger cables to the battery nice and tight and clean. I have the plug itself routed behind the wheel liner and it pops out just behind my passenger fog lights.
Now I just need to figure out where I’m mounting the Noco Plug Port and one day get around to installing my block heater and cord. Luckily it’s been a mild winter up here in NY. So, I’ll be sure to get that done before next winter.
I have the modular number - so, I’m currently thinking in the center section of the bumper - either up top or down below the intercooler. Otherwise, I have that dummy plastic box in the middle of the intercooler (since I don’t have sensors) - thought it might work mounted there dead center.
redone17
Cold Spring, NY
Finally got around to this. Noticed there is JUST the right amount of space to mount the Noco Power Plug next to the fairlead on my RC Hidden Winch Skid Plate.
The screws that come with the Noco are trash. So, I got some high quality black oxide torx screws and washers from Grainger. They’re a bit long - but, they did the trick.
Now I just need to clean up the wiring and install the block heater at one point.
Ford Bronco On board battery maintainer 2F8947C6-1FDC-499E-9778-AAB0C1284541
Ford Bronco On board battery maintainer 199D2BEC-DB86-4953-8A7C-E925BA8D1A57
redone17
Cold Spring, NY
Tight and tucked! Water/dust proofed with some A Plug Pro gaskets, dielectric grease, heat shrink wrapped and zip tied to the crossmember with the extraneous cord stored behind the wheel liner. Second plug is for the block heater when I finally get around to that install. Super happy with how this turned out.
Now I just need to research smart plugs so that I can remotely turn on or off power to the block heater if I just want to run the maintainer/charger.
Ford Bronco On board battery maintainer IMG_3916
Ford Bronco On board battery maintainer IMG_3915
Ford Bronco On board battery maintainer IMG_3914
