Oil life indicator?
Aimless
Dennis
2025 Bronco
I can't find the oil life indicator on my 2025 Bronco Badlands. Does it have one and where is it?
Are there any other maintenance reminders, like air filter?
Thanks
Ducati1098
Thanks
In the cluster:
Main menu > Settings > Vehicle Maintenance > Oil life
Oil life is the only maintenance reminder.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
adam1991
VW GTI (2)
Thanks
User manual.
wgw
bill
Va
2023 Black Diamond Bronco
Thanks
so ever given thought to getting it tested prior to changing it? A lot of useful DATA comes from a test, like useful life left, or past useful life, fuel dilution , TAN, TBN, wear metal amounts..Its good real data to help decide when you should safely get it changed, rather then base that decision on a bunch of assumptions , which may or may not be applicable to ur engine, driving style and conditions.....Nice to know if whats happening for real, not needed every change but once you have established a baseline you choose how often you retest, not real $$...
Gluestick
Josh
Nashville
instagram.com
Explorer ST, Bronco Badsquatch
Where do you get that done?
Headsong
Don't use it. When odo is divisible by 5000, change it. Every mechanic will tell you that.
