Off roading flag mount recommendations?
Robs
Rob
New hampshire
2023 Black Diamond
The TrailSite bracket came from Trailrax:
https://trailrax.com/products/ford-bronco-trail-sight-accessory-mount
The Flag is from HandyFlag, and I ordered 2 of the mounting studs. The second is on the back, atop the Hammerbuilt reinforcing bracket, on an accessory bracket.
https://www.handyflag.com/product-page/ford-bronco-handy-flag-kit-1
I don't like the flat tailgate mounts, I want more offset away from the car.
Nice setup. What rear bracket is that for your rotopax?
lakesinai
Charleston SC
It's the Hammerbuilt accessory arm
https://hpbuilt.shop/products/hammer-built-bronco-tailgate-support-accessory-arm
Added to the Hammerbuilt reinforcement system
https://hpbuilt.shop/products/hammer-built-bronco-tire-support-kit
To which I added Rotopax's own mounting brackets, which fit the Hammerbuilt holes (you need an extension to fit two containers). Ask then to help you buy the correct parts if needed.
https://www.rotopax.com/products/dlx-pack-mount
Which I may have bought ftom Bronco Nation. However, they no longer have it, it seems.
Here's a photo of the two-can bracket. The white spots are WD-40 lithium spray, which I use on all holes to keep salt water corrosion at bay. These accessory brackets come off and on seasonally.
Ford Bronco Off roading flag mount recommendations? 20240921_125118
Robs
Rob
New hampshire
2023 Black Diamond
Thank you!
The Beaz
Shad
San Francisco
I second the handyflag....Have mine on the rear bumper.....Love it
Ford Bronco Off roading flag mount recommendations? PXL_20230827_212701180.jpg_compressed.JPEG
Ford Bronco Off roading flag mount recommendations? PXL_20230827_212622939.jpg_compressed.JPEG
Qarlos
Caleb
Doha, Qatar
2022 Bronco Wildtrak
The handyflag is super convenient to store and deploy. I have it and use it all the time. Just be aware that it is not a very strong flag pole and it sways a lot. If you mount it near the body it will bang if you are going over any significant bumps. I have it mounted on a bracket attached to my spare tire carrier.
The best flag pole mount I have seen is by KC Hilites. One for the Bronco and another model for the Bronco Raptor. They bolt behind the spare tire and are very sturdy.
(photo from the KC website. I don't have this mount, but my friend does)
Ford Bronco Off roading flag mount recommendations? 7477-13
CalvinT
Calvin
Phoenix, AZ
I don't plan on driving anywhere that requires an off roading flag. But I'm going to get a flag mount for the trail sights. So many parking garages have height limits. So I'll cut a trail flag so it's a few inches taller than the load I'm carrying on my roof rack. It will give me a visual guide anytime I enter a covered garage.
BroncoChallenger
2024 Bronco
Which end are you looking to put the flag? @Mountains2Metal makes one that mounts on the spare tire mount and there are others that mount using the trail sights.
https://mountains2metal.com/tailgate-flag-antenna-mount-bracket-v2-passenger-bronco-6g-2021/
https://www.ebay.com/itm/1160403463...3yh6jEQQrS&var=&widget_ver=artemis&media=COPY
Looking at getting both the right and left from them...they're pretty inexpensive and look pretty solid. We may not put an actual flag on there but definitely debating some whips just for looks.
M2M doesn't have a huge selection of parts, but what they do have seems to be pretty quality. Bought the steps that bolt onto the factory rock rails, and they're solid.
BroncoChallenger
2024 Bronco
Question on that reinforcement bracket...does it help quiet down any squeaks/rattles from the back? I've noticed that our rear window squeaks sometimes when going over bigger bumps on the highway and I'd like to quiet it down. If it doesn't I'm not going to mess with it, but if it does I might drop the $200+ for it...looks easy enough to install.
lakesinai
Charleston SC
Hard for me to compare. I've only a 33" Badlands wheel on the back, you have a 35" SAS. I would think the bracket would help you, but there are still squeaks-- the Skyrider softtop squeaks as does the hardtop in certain conditions. My rear window doesn't squeak, AFAIK. My main reason for the reinforcement bracket was to have a safe and reliable accessory mounting capability. It is that, plus flags (or antennas, if needed). Coupled with the half-rack and one of the side saddles, it's excellent for me. When loaded up, it doesn't seems to squeak much . . . And I sometimes carry bikes as well. Also, two full gas cans is more extra weight than your SAS tire compared to my 33" . . .
Ford Bronco Off roading flag mount recommendations? 20240927_095729
Ford Bronco Off roading flag mount recommendations? SmartSelect_20240407_162813_Gallery
Ford Bronco Off roading flag mount recommendations? 20240410_161641
BroncoChallenger
2024 Bronco
Thanks for that info! I'll be taking a look at it for sure. I know Jeeps used to have a hinge upgrade available for the bigger tire packages, wasn't sure if Ford did it right from the get-go or if something extra was needed.
lakesinai
Charleston SC
The only OEM Ford hinge upgrade AFAIK is the Raptor build, SAS and below are the same, hence the aftermarket tailgate reinforcements like Hammerbuilt, growing in number. Check the threads here.
Aaeros
Douglas
Houston, Tx
2007 Toyota Tacoma
I just bought this mount and it doesn't fit. The arch over the factory rear camera doesn't have enough clearance so the bolts dont align. I have reached out to KC HiLiTES.
Ford Bronco Off roading flag mount recommendations? 20241107_182303
