- First Name
- Brian
- Joined
- Sep 14, 2023
- Threads
- 62
- Messages
- 8,357
- Reaction score
- 14,815
- Location
- Central CA
- Vehicle(s)
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Your Bronco Model
- Big Bend
- Thread starter
- #1
The tl;dr up front is I have a locker and I can't get it to work.
I bought a take off rear end back around Christmas so I could add a rear locker to my 4.46. Got it installed right after New Years.
Not having factory lockers, I ran the wiring to a relay. When I first installed it - it clicked and locked once. I unhooked it to clean up the wiring, and when I reconnected it, it blew fuses. Going down that path of troubleshooting, I found the coil itself was shorted - 0 ohms at the pigtail coming directly off the coil.
So, I did some research, a lot of it is around here. I ordered new parts:
It took a while for the parts to get in, the carrier bearing was backordered until just this week. Today was the first day I had to get into it and replace the coil. It sounded easy - just pull the axles back, pop the carrier out, pull the right carrier bearing, and swap the coil.
Here's the carrier, this is after I got it out with the old coil in it. It looks identical when I got it put back together.
Just for the sake of completeness, here's a picture of the pinon with the carrier pulled.
Apart from the carrier bearing being an absolute pain to get off, there wasn't much to it. Put it all back together - doesn't work still.
I don't blow fuses anymore, so there's that. But the coil doesn't engage. No click, and doesn't lock - checked by jacking up one tire and spinning it.
Brand new coil out of the box was 4 ohms. Installed, checking resistance all the way back to the relay with everything plugged in, I'm getting 4.2 ohms. So that looks good. I'm getting 12V at the outer plug, and on the internal side of the plug - so that looks good. Polarity matches the Red (+) on the coil wiring.
When I turn on the coil, with a clamp on I can see current spike a bit and then settle down to around 4 amps. Swapped relays just in case it was something goofy with that.
Pretty sure everything went back the way it came apart - there wasn't exactly a lot to it - a small plate underneath the coil, the coil, and the carrier bearing. The little catch on the carrier housing that hitches a welded pin on the coil.
I can't even really think of anything else to check. Any ideas? Maybe it's working and I just am not testing it right? I'm stumped.
