New Product Release: IAG I-Line Mini Mud Flaps
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
Can we get a full frame picture with front and rear flaps showing installed?
These are not really designed to go in the rear. You could put them in the rear if you wanted to, but they would be in front of the rear tire. I can certainly post up a full frame shot later today though.
bradcd
Brad
Indiana
Saab 9-3
Gotcha. I was just hoping to see how they looked zoomed out showing the whole truck.
joeb
Joe
Pennsylvania
FJ Cruiser
I would totally buy if there was a factory tube step option. I would also like to see for rears ---- maybe where the Sasquatch flare has that added piece in the back. Two screws
sjjohnny
El Paso
'22 Bronco Black Diamond, '00 Tacoma
Perfect, just ordered.
Wickedbronco
Jon
Chicago
For those who have these, are they large enough to help with rock chips?
Techun
Pa
BD, 2.7, MIC, 4dr
Also interested in reviews
GoHack
Palmdale, CA
'25 Bronco, 2.3L 4-Cylinder, 7 Spd. Manual, 4 Door
Great design, easy to install, and not too big.
My compliment to the person who thought of it and designed it.
Have a set on order for my BD. 👍
Justinfro
Justin
Tulsa
4Runner, Cayman S (987.2), 911sc
Had to send mine back. Unfortunately they do not work with the Ford bolt on side step rails.
Abundigas
New England
Base Squatch 2D
How about a similar set that either replaces the end cap of the Tube Step, or can mate up with the Crash Bar slot on the Sasquatch.. Ill be your Beta tester.
OscarHTX
Houston/TEXAS
I bought these for my black diamond and they dont fit. Seems like a different shape of rock rail? These are rock rails from the factory, 2023 Bronco. Just picked her up yesterday.
Ford Bronco New Product Release: IAG I-Line Mini Mud Flaps 20230819_224935
Ford Bronco New Product Release: IAG I-Line Mini Mud Flaps 20230819_073402
Bellime
Keith
2022 Ford Bronco
Well, I have definitely found that you should start with good front flaps, rear are not as useful, even while 4x4 mode.. finding good front flaps, that are durable, is not easy.
the back set is a different issue as they need to function within the approach/descent angle and side approach vector.
my rear flaps have already been permanently removed. I need my reverse angles as much as my forward.
But I have another vendors front flap solution, i am not happy with everyone’s solution yet.
they all suck, right now, you can only make due for a temp solution at a reasonable price.
mdk100
Los Angeles
Porsche 911, Cayenne, BMW X3e, 2 door BaseSquatch
Just installed mine today. I did a bit of surgery with a dremel to add the old caps onto the mud flaps. I wanted to fill in the indentation, as that looked like a mud magnet. They look good, but will have to see how they function. I didn’t want a massive flap, so these are definitely more subtle.
