IntownBadlands
Karl
Atlanta
2021 Badlands Sasquatch Lux
Are the anti-shock pads for friction marks alone or noise/rattle?
I noticed the instructions mention front and back, but your install video only discusses the rear.
Prepped the rears for installing tomorrow. These will be installed for winter months only. I like that I can leave the mounting brackets installed without being an eye sore and just bolt on the flaps as needed.
Solid materials. I too will be looking to replace the visible bolts with black.
I would test fit them before adding the foam.
IAG Performance
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
The anti-shock pad is mainly friction marks, but also serves the purpose of cutting down and noise, just in case.
We found that it was really only required on the rear.
We found that the original black hardware was prone to rust, so we decided to change it out with stainless hardware to prevent that.
ForFoxSake
Canada
2022 Ford Bronco Wildtrak
Any new updates by guys who have had these for awhile? Any regrets? I was going to by the rokblokz mudflaps for no hassle install....but they cost a fortune.
I wanted these for a 22 Bronco Wildtrak with the factory running boards.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I just installed this morning - it was pretty straightforward and no hang ups or suggestions outside of the IAG video tutorial. I opted against the foam padding. Doesnā€™t seem necessary and I felt it would be easier to clean out salt, dirt, mud without them.
Planning to run them for winters only. Iā€™ll report back. I actually like the fit and finish on standard flares. Iā€™ve got 1.5ā€ spacers with Black Diamond Steelies and itā€™s JUST the right amount of coverage. The materials match pretty well too.
swooshdave
Portland, Oregon
Mustang
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
Broncoman23
2022 Bronco Wildtrak
@IAG Performance I have these and they work great. I will hear a rock hit the mudflap but not the side of the Bronco anymore. They very much look like they belong here, didn't like the gap between the fender and the running board. These fill that gap perfectly. I only have the fronts.
Ford Bronco New Product Release: IAG I-Line Mud Flaps mudflap1
Ford Bronco New Product Release: IAG I-Line Mud Flaps mudfla2
Ford Bronco New Product Release: IAG I-Line Mud Flaps mudflap3
IAG Performance
IAG Performance
JJ
Westminster, MD
These are the Mabett Mud flaps.
These are not Mabett Mud flaps. Contrary to popular belief Mabett is not the manufacturer. We work with their manufacturer as well as many other manufacturers in various different countries for our I-Line of products. There are some key differences between ours and Mabett's. Our mud flaps come with stainless steel hardware, an additional body clip for the front mud flaps, they have a 3-year warranty, are in stock in our warehouse located in Westminster, MD and you can always reach one of our US-based support representatives with any questions.
IAG Performance
IAG Performance
JJ
Westminster, MD
@IAG Performance
https://www.iagperformance.com/weat...e-size-no-drill-mudflaps-black-110140-120145/
Product page does not indicate if this is for all four wheels.
Can you add the 2023 Bronco to your fitment? They will be showing up real soon like.
Description says for 315 tire but says it won't fit any Broncos except First Edition. Obviously it should fit all Wildtracks and any one with Sasquatch, correct?
Just to be clear, these are not our IAG I-Line mudflaps. These are made by Weathertech.
With that said, this kit is for front and rear. We pull fitment data directly from the manufacture for products not made by us, so once Weathertech updates their fitment data, ours will be automatically updated.
Theoretically, they should fit any Sasquatch Bronco with 315 or down sized tire. But again, these are Weathertech mudflaps, not ours.
swooshdave
Portland, Oregon
Mustang
Yes, I understand this thread is about your flaps. I just wanted to point out some discrepancies on your site regarding other flaps you offer. I'm not sure why you even offer the Weathertech flaps given they are so similar to your own.
sgkartracer15
Adam
Atlanta
Man, those before and after pics and the ones with the mud are great. Just ordered a set of the fronts off ole Amazon. Look forward getting them on my Bronco. (y)
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
Waiting for bronco raptor flaps
Offroadrob
Rob
Summit county Colorado
19 TRD PRO, 10 Cayman S
IAG I-Line Mud Flaps Protect Your Investment
The IAG I-Line Mud flap Set is designed to mount using existing holes, no cutting or drilling is required for mounting. Once installed, these flaps provide an extra layer of protection between your tires and your paint. Mud, snow, ice, and other road debris simply bounce off of these flaps before hitting the side of your truck. These mud flaps are designed for street and light offroad use. Unlike others on the market, our mudflap set includes longer stainless hardware to make installation a breeze. We also include a replacement factory-style body clip to ensure a secure connection to your Bronco. Clears OEM tires with stock offset wheels even on Sasquatch Package equipped Broncos. These mud flaps work perfectly with the OEM rock rails found on some Bronco models. Removal of the factory crash bar is not required for installation.
IAG I-Line Mud Flap Front and Rear Set
Constructed of high-quality ABS Plastic, these mud flaps resist scratching and cracking. They feature a small IAG mountain logo in each corner. ABS plastic is very durable and designed for this type of application. These flaps look great and provide superior protection from the elements.
SHOP NOW
IAG I-Line Mud Flap Set *Front Only*
The IAG I-Line Two Piece Front Mudflap Set includes flaps for the front of your Bronco only. Designed to mount using existing holes, no cutting or drilling is required for mounting. Once installed, these flaps provide an extra layer of protection between your tires and your paint.
SHOP NOW
Any idea when these will be back in stock?
