New Grab Handles on Amazon
RowsKing
JR
SJ
22 BRaptor, 66 Stang
To those that say you won’t hit your head on them in an incident. You bounce around. You don’t stay firmly planted in the seat with OEM belts.
It’s not that you won’t or can’t hit your head with these in an accident, it’s that those odds of it actually happening are extremely low. For most of us, we don’t live life based on those type of odds.
Heckler
Larry
San Mateo
2023 Bronco
Problem with these types is there too high and should you be using them in a roll over situation your fingers are going to get chopped off between the handle and the hard top or ground if you have the top off.
fourdayoff
Boulder City Nv
2022 Bronco Badlands/sasquatch 2.7
I bought the OP's handles and was disappointed in how close they were to the top, couldn't get my fingers all the way through. I milled wedge washers to angle them slightly down and now they work great. I don't use them for getting in but they are great for stabilization, far enough away not to be a hazard. Weird things happen in crashes so only 5 point harness is truly safe.
Aman
Aman
Northern NJ
I have these. Simple and clean.
Ford Bronco New Grab Handles on Amazon 81bJ9KIdNdL._AC_SL1500_
RedDawg
Erik
PHX AZ
WLDCATR
KW
DFW, TX
Bronco Wld '22 - 24 RSQ8 Audi
Bartact.com has great grabs... plus door pockets and such... easy to grab onto entering the truck and for those 'wicked' turns/hills/valleys and OS's!
Ford Bronco New Grab Handles on Amazon 1685573089344
Ford Bronco New Grab Handles on Amazon 1685573129344
James Cole
MX
Badlands Sasquatch (hopefully)
This TO ME… are the best…
simple and clean plus they come with a high density foam where you put your arm for comfort and heat insulation (not shown on the picture), yes for some reason parked on a sunny day they get very hot.
Ford Bronco New Grab Handles on Amazon CAF75EDF-4C43-48BE-9506-9F9DE9F7C518
Aman
Aman
Northern NJ
True, but the plastic separates outward to allow the airbags release.
This is a nonsensical statement. All of these handles attach utilizing stock bolt locations. The stock bolts do not magically allow the plastic to release in the event of an accident. The plastic is simply pushed out of the way when the airbag inflates. Installing grab handles will not affect this.
RedDawg
Erik
PHX AZ
No, installing handles won’t prevent the air bags from deploying. But they might turn into projectiles.
Aman
Aman
Northern NJ
Again, the bolts do not and will not magically release in the event of an accident. So no, they will not turn into projectiles.
RedDawg
Erik
PHX AZ
No not magic, physics.
Buckethead
Denver, CO
‘21 Exp ST, ‘22 Base 2dr & ‘23 2dr Badlands
I’d love a handle here but I’m torn. The airbag will release but you’ll be in a world of hurt if you’re holding that handle when it does - regardless if if it’s a rigid handle or not. Now, prolly not an issue during daily driving because thats not a natural driving position but you put it on the lid crawling and your passenger will likely have their hand there through that process. If broncobuster has thought us anything its that airbags deploy when you roll it.
soupcansam
Kentucky
Can you post some pictures of the foam and heat insulation?
The Compensator
Cleigh
Wichita, ks
1994 bronco, 2015 yukon denali xl, minivan
those are really nice 👍👍 great find
I agree, nice find! What color interior do you have? Any pictures installed? Thanks!
James Cole
MX
There you go, plus if you have heavy muscular arms like I do, it kind of hurts my also princess hands holding onto thin bare metal lol...
Ford Bronco New Grab Handles on Amazon tempImagealNdGD
