Thor_1
2026 Bronco Heritage
Is there a way to factory reset if needed. Basically remove any evidence of your product.
JFelty
Minnesota
Mustang Mach E
Nick72
Nick
North GA
2021 Bronco Base(Traded), 2025 Bronco Outer Banks
We've added support for all 21-26 Bronco models (including BRaptors!) to our awesome Flashcal+ mobile options device!
Part number SC-MOD allows Bronco owners to calibrate the speedo, control TPMS settings, change vehicle convenience settings, adjust audio controls, configure lighting options, and more!
The Flashcal+ is a mobile solution, with a Free iOS or Android app available for complete control from your smartphone. All options are easily managed through an intuitve and easy to use app, allowing for simple on/off or enable/disable selections. No more writing code! No more guessing! No more hoping you didn't create a new problem! And best yet, no more dragging a laptop out to your bronco to make changes.
At $199.95, this might be the best value in the Bronco aftermarket!
Check out this list of features and options, available right out of the box!
Audio Configuration
  • Equalizer Assist - Enable/Disable
  • Fake Engine Noise - Enable/Disable
  • Active Noise Cancellation - Enable/Disable
  • Front Door/Dash Speakers - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker / B&O Speakers
  • Front Center Speaker - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker
  • Rear Pod Speakers - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker / B&O Speakers
  • Subwoofer Speaker - No Subwoofer / Subwoofer
GOAT Modes
  • Sport Mode - Enable/Disable
  • Rock Crawl Mode - Enable/Disable
  • Baja Mode - Enable/Disable
  • Off-Road Mode - Enable/Disable
  • Note: Available on 2026 Bronco 2.3L/2.7L and 2022–2026 Bronco Raptor 3.0L.
  • Slippery Mode - Enable/Disable
  • Tow Mode - Enable/Disable
  • Eco Mode - Enable/Disable
  • Note: Available on 2021–2026 Bronco 2.3L/2.7L only.
  • Mud/Ruts Mode - Enable/Disable
  • Note: Available on 2021–2025 Bronco 2.3L/2.7L only.
  • Sand/Snow Mode - Enable/Disable
Lighting Configuration
  • Daytime Running Lights - Enable/Disable
  • Fog Lights - Enable/Disable
  • Lock Feedback Light - Enable/Disable
  • Headlamps Position - Auto Lamps / Last Known
  • Auto Lights Delay - 0s / 5s / 10s / 15s / 20s / 60s / 120s
Service Options
  • Recalibrate Speedometer - Enable/Disable
Speedometer Adjustments
  • Tire Size (Imperial & Metric) - Height: 28.25"–36.25"; Includes Aspect Ratio input
TPMS Adjustments
  • TPMS Alert Threshold Front - 1–90
  • TPMS Alert Threshold Rear - 1–90
  • TPMS Enable/Disable - Enable/Disable
Tire Size Wizard
  • GPS Based Tire Size Wizard
Vehicle Configuration
  • Auto Lock - Enable/Disable
  • Auto Relock - Enable/Disable
  • Auto Unlock - Enable/Disable
  • Door Chime - Enable/Disable
  • Engine Shutdown - Enable/Disable
  • Global Windows Down - Enable/Disable
  • Global Windows Up - Enable/Disable
  • Honk Warning - Enable/Disable
  • Navigation in Motion - Enable/Disable
  • Panic Alarm - Disable / Single Press / Double Press
  • Power Point Timeout - Disable / 10m / 30m / 1hr / 75m / 3hr
  • Remote Start Duration - 0s / 5m / 10m / 15m
  • Remote Unlock - Driver's Door / All Doors
  • Screen Config - 8-inch Landscape / 13.2-inch Lincoln / 13.2-inch Ford / 12-inch Landscape
  • Seat Belt Minder - Enable/Disable
  • Silent Mode - Enable/Disable
  • Startup Chimes - Enable/Disable
  • Steering Wheel Temp - 75°F–102°F
  • Turn Signal Volume Down - Enable/Disable
Auto Start-Stop
  • Auto Start-Stop - Enable/Disable
  • Note: Available on 2021–2022 Bronco 2.3L/2.7L and 2022 Bronco Raptor 3.0L only.
What is "silent mode"?
And does it support Fog lights on with highbeams? Is that what is meant by fog lights enable/disable?
Thanks!
Fordified1
Bob
Mid South Texas
Yep, I have a Wolfbox RV Mirror and use the OBD connection for it, don't want to hard wire it yet, but the flashcal looks very promising...
You can get an OB2 splitter cord and tuck the ends up under the dash. I have one on my excursion.
Fordified1
Bob
Mid South Texas
@Superchips_Mktg tell us about the tow mode? Broncos at least 21-24 do not and never have had a tow mode. I have tried multiple times to get some sort of tow mode operational. As we pull a small camper I’d be most interested in seeing this in pictures and video. As far as I’ve been told only the raptor variants have a tow mode.
I think when you connect the trailer wiring to the Bronco it automatically puts you in a “tow mode” of sorts. It engages anti-sway and stops blind spot monitoring maybe more idk. I have towed over weight for a short distance and the anti sway works surprisingly well.
N8do
Nate
IN
24 Badlands Sasq hardtop 2.7 /86 4X4 trim, 351W, 35s, 4.86 + lockers /02 Taco 4d
Audio Configuration
GOAT Modes
Service Options
TPMS Adjustments
Tire Size Wizard
Auto Start-Stop
The regular Flashcal, not +, says it calibrates up to a 42 inch tire. Why the difference now to just 36.25?
Tacoman
Matthew
Fayetteville, AR
2026 Shelter Green Braptor, 2026 Defender 110, 2025 Badlands
So...
if i have 2 broncos can i use one on both? or are they exclusive to each Bronco....
And, is it capable of enabling the 3 auxiliary lights in front grill with DRLs?
N8do
Nate
IN
In cart y'all! I hadn't even pulled the trigger on the Forscan or Procal4 yet and came across this, this morning. Perfect timing!
N8do
Nate
IN
So...
Excellent question.....was hesitant to ask. :whistle:
