‘21OBX
Ken
90Bronco19
2022 bronco outer banks
@Superchips_Mktg tell us about the tow mode? Broncos at least 21-24 do not and never have had a tow mode. I have tried multiple times to get some sort of tow mode operational. As we pull a small camper I’d be most interested in seeing this in pictures and video. As far as I’ve been told only the raptor variants have a tow mode.
Valhalla
Valhalla
Chattanooga Tn
If there's a feature or option that you don't see listed, but would love to have, we'd love to hear it!
Stabilizer bar disconnect at any speed, rear locker in 2wd front locker in 4hi
Trialmx
Jack
Ohio
2022 Bronco
I'M in if you can remove restrictions in the Center display dimming adjustment. The center display used to have a slide bar that went full left (not off but very dim) and full right (bright). A software update in 2023 limited the amount the slide bar would travel resulting in a brighter screen illumination lowest setting. A later update changed the slide bar to a numeral scale, both of these update resulted in a screen that is too bright for my liking when driving at night. I have posted about this with photos in my profile that you could check out. Thanks
Bevans86
Bill
Harrisburg, Pennsylvania
2022 Bronco Outerbanks- Velocity Blue
We've added support for all 21-26 Bronco models to our awesome Flashcal+ mobile options device!
Part number SC-MOD allows Bronco owners to calibrate the speedo, control TPMS settings, change vehicle convenience settings, adjust audio controls, configure lighting options, and more!
The Flashcal+ is a mobile solution, with a Free iOS or Android app available for complete control from your smartphone. All options are easily managed through an intuitve and easy to use app, allowing for simple on/off or enable/disable selections. No more writing code! No more guessing! No more hoping you didn't create a new problem! And best yet, no more dragging a laptop out to your bronco to make changes.
At $199.95, this might be the best value in the Bronco aftermarket!
Check out this list of features and options, available right out of the box!
Audio Configuration
  • Equalizer Assist - Enable/Disable
  • Fake Engine Noise - Enable/Disable
  • Active Noise Cancellation - Enable/Disable
  • Front Door/Dash Speakers - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker / B&O Speakers
  • Front Center Speaker - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker
  • Rear Pod Speakers - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker / B&O Speakers
  • Subwoofer Speaker - No Subwoofer / Subwoofer
GOAT Modes
  • Sport Mode - Enable/Disable
  • Rock Crawl Mode - Enable/Disable
  • Baja Mode - Enable/Disable
  • Off-Road Mode - Enable/Disable
  • Note: Available on 2026 Bronco 2.3L/2.7L and 2022–2026 Bronco Raptor 3.0L.
  • Slippery Mode - Enable/Disable
  • Tow Mode - Enable/Disable
  • Eco Mode - Enable/Disable
  • Note: Available on 2021–2026 Bronco 2.3L/2.7L only.
  • Mud/Ruts Mode - Enable/Disable
  • Note: Available on 2021–2025 Bronco 2.3L/2.7L only.
  • Sand/Snow Mode - Enable/Disable
Lighting Configuration
  • Daytime Running Lights - Enable/Disable
  • Fog Lights - Enable/Disable
  • Lock Feedback Light - Enable/Disable
  • Headlamps Position - Auto Lamps / Last Known
  • Auto Lights Delay - 0s / 5s / 10s / 15s / 20s / 60s / 120s
Service Options
  • Recalibrate Speedometer - Enable/Disable
Speedometer Adjustments
  • Tire Size (Imperial & Metric) - Height: 28.25"–36.25"; Includes Aspect Ratio input
TPMS Adjustments
  • TPMS Alert Threshold Front - 1–90
  • TPMS Alert Threshold Rear - 1–90
  • TPMS Enable/Disable - Enable/Disable
Tire Size Wizard
  • GPS Based Tire Size Wizard
Vehicle Configuration
  • Auto Lock - Enable/Disable
  • Auto Relock - Enable/Disable
  • Auto Unlock - Enable/Disable
  • Door Chime - Enable/Disable
  • Engine Shutdown - Enable/Disable
  • Global Windows Down - Enable/Disable
  • Global Windows Up - Enable/Disable
  • Honk Warning - Enable/Disable
  • Navigation in Motion - Enable/Disable
  • Panic Alarm - Disable / Single Press / Double Press
  • Power Point Timeout - Disable / 10m / 30m / 1hr / 75m / 3hr
  • Remote Start Duration - 0s / 5m / 10m / 15m
  • Remote Unlock - Driver's Door / All Doors
  • Screen Config - 8-inch Landscape / 13.2-inch Lincoln / 13.2-inch Ford / 12-inch Landscape
  • Seat Belt Minder - Enable/Disable
  • Silent Mode - Enable/Disable
  • Startup Chimes - Enable/Disable
  • Steering Wheel Temp - 75°F–102°F
  • Turn Signal Volume Down - Enable/Disable
Auto Start-Stop
  • Auto Start-Stop - Enable/Disable
  • Note: Available on 2021–2022 Bronco 2.3L/2.7L and 2022 Bronco Raptor 3.0L only.
any performance mods/tune available like it is for the Jeep?
JFelty
Stroppe
Minnesota
Lincoln Corsair Hybrid (Plugin)
Stroppe
I've been running the Ford Performance ProCal Tune for 4 years now would there be any issues with using both at the same time? I would like to use it to change some of the inconvenient things and add tow mode so I don't have to listen to the alarm when backing up while towing
Superchips_Mktg
Superchips_Mktg
Jacob
Sanford, FL
www.holley.com
2022 Bronco
Can the hand held Flash Cal be updated for these new features as well?
No, but we'll get you hooked up if you want to trade in for the SC-MOD!
Superchips_Mktg
Superchips_Mktg
Jacob
Sanford, FL
www.holley.com
2022 Bronco
I have FORScan which does most of what I need, but it’s cumbersome to use. I’d be 100% sold on this if you found a solution to:
  1. Disable the 6 mph speed limit for mirror spot lights.
  2. Disable the 6 mph speed limit for 360deg Camera views in all modes (I.e. pavement modes Normal, ECO, & Sport where it is currently limited)
Ford Bronco {thread} {filename}
We'll look into these asap!
Superchips_Mktg
Superchips_Mktg
Jacob
Sanford, FL
www.holley.com
2022 Bronco
No issues, they should complement each other.
