MDrums
Tampa
Bronco Raptor
You said " Bronco's"....just making sure Raptor is part of that.
razehound
SoCal
2025 Bronco
Can you provide which ones will remain programed or not? Whichever list is shorter to save keyboard ink....
Yeah i already know Id buy it and then find out the one setting i really care about requires a constant connection...
TraumaJoe
Joseph
Roseville, CA
Jeep Wrangler Unlimited Rubicon JK
This looks great!!!!
I have 2 requests if possible
1. Ability to electronically disconnect the sway bar in 2wd
2. I see you can adjust tire size, but only up to 36.25 inch. Go at least to 37 inch or even bigger.
Alassise
Al
Yep, I have a Wolfbox RV Mirror and use the OBD connection for it, don't want to hard wire it yet, but the flashcal looks very promising...
BAUS67
redneck
Central PA
We've added support for all 21-26 Bronco models to our awesome Flashcal+ mobile options device!
Part number SC-MOD allows Bronco owners to calibrate the speedo, control TPMS settings, change vehicle convenience settings, adjust audio controls, configure lighting options, and more!
The Flashcal+ is a mobile solution, with a Free iOS or Android app available for complete control from your smartphone. All options are easily managed through an intuitve and easy to use app, allowing for simple on/off or enable/disable selections. No more writing code! No more guessing! No more hoping you didn't create a new problem! And best yet, no more dragging a laptop out to your bronco to make changes.
At $199.95, this might be the best value in the Bronco aftermarket!
Check out this list of features and options, available right out of the box!
Audio Configuration
  • Equalizer Assist - Enable/Disable
  • Fake Engine Noise - Enable/Disable
  • Active Noise Cancellation - Enable/Disable
  • Front Door/Dash Speakers - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker / B&O Speakers
  • Front Center Speaker - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker
  • Rear Pod Speakers - Speaker Only / Tweeter Only / Speaker and Tweeter / No Speaker / B&O Speakers
  • Subwoofer Speaker - No Subwoofer / Subwoofer
GOAT Modes
  • Sport Mode - Enable/Disable
  • Rock Crawl Mode - Enable/Disable
  • Baja Mode - Enable/Disable
  • Off-Road Mode - Enable/Disable
  • Note: Available on 2026 Bronco 2.3L/2.7L and 2022–2026 Bronco Raptor 3.0L.
  • Slippery Mode - Enable/Disable
  • Tow Mode - Enable/Disable
  • Eco Mode - Enable/Disable
  • Note: Available on 2021–2026 Bronco 2.3L/2.7L only.
  • Mud/Ruts Mode - Enable/Disable
  • Note: Available on 2021–2025 Bronco 2.3L/2.7L only.
  • Sand/Snow Mode - Enable/Disable
Lighting Configuration
  • Daytime Running Lights - Enable/Disable
  • Fog Lights - Enable/Disable
  • Lock Feedback Light - Enable/Disable
  • Headlamps Position - Auto Lamps / Last Known
  • Auto Lights Delay - 0s / 5s / 10s / 15s / 20s / 60s / 120s
Service Options
  • Recalibrate Speedometer - Enable/Disable
Speedometer Adjustments
  • Tire Size (Imperial & Metric) - Height: 28.25"–36.25"; Includes Aspect Ratio input
TPMS Adjustments
  • TPMS Alert Threshold Front - 1–90
  • TPMS Alert Threshold Rear - 1–90
  • TPMS Enable/Disable - Enable/Disable
Tire Size Wizard
  • GPS Based Tire Size Wizard
Vehicle Configuration
  • Auto Lock - Enable/Disable
  • Auto Relock - Enable/Disable
  • Auto Unlock - Enable/Disable
  • Door Chime - Enable/Disable
  • Engine Shutdown - Enable/Disable
  • Global Windows Down - Enable/Disable
  • Global Windows Up - Enable/Disable
  • Honk Warning - Enable/Disable
  • Navigation in Motion - Enable/Disable
  • Panic Alarm - Disable / Single Press / Double Press
  • Power Point Timeout - Disable / 10m / 30m / 1hr / 75m / 3hr
  • Remote Start Duration - 0s / 5m / 10m / 15m
  • Remote Unlock - Driver's Door / All Doors
  • Screen Config - 8-inch Landscape / 13.2-inch Lincoln / 13.2-inch Ford / 12-inch Landscape
  • Seat Belt Minder - Enable/Disable
  • Silent Mode - Enable/Disable
  • Startup Chimes - Enable/Disable
  • Steering Wheel Temp - 75°F–102°F
  • Turn Signal Volume Down - Enable/Disable
Auto Start-Stop
  • Auto Start-Stop - Enable/Disable
  • Note: Available on 2021–2022 Bronco 2.3L/2.7L and 2022 Bronco Raptor 3.0L only.
Bigger tire sizes. Broncos have biiig wheel wells. 36.25 fits a Squatch with only a max tire kit, no lift kit required. Add a lift kit to that and we are in the 38+ range.
Front and/or rear lockers, although I don't have a sway bar disco but I'm sure those guys who do would like it not to shut off, so they work at higher speeds. I don't think that is possible, but worth a shot.
one last one.......... be able to change the daytime running light mode. Use the amber turns as DRL. or maybe some would like to use the fogs as DRL.
I might think of more but that is a start. 😁
timhood
Tim
Several
Ability to keep the sway bar disconnected to a higher speed, like 30-35mph. I'd even leave the device plugged in if the only way to accomplish this was to fool the ECU into thinking the Bronco was going slower than it was. I feel like the real answer to these two features is getting a Ford engineer to let us know the address and value of the the settings to change. :) I'm OK with anonymous reporting. ;)
timhood
Tim
Several
If there's a feature or option that you don't see listed, but would love to have, we'd love to hear it!
How about being able to enter/exit brake service mode and similar features, including battery management system reset? Yes, these can be done with the odd dance of button, pedal and switch sequences, but having a simplified method is a nice value-add.
I assume that features added after purchasing the device can be added to the device with a firmware update or similar process.
Tybh88
Tyler
How about compatibility for 23,24,25 models
