Need VINs for suspension IDs
flip
Phil
IN
www.ruxerparts.com
Fords
Several folks have inquired about upgrading their suspensions to BL or SAS so I'm trying to gather VINs to make sure the springs are correct for the application.
What I need. VINs for 2d BL with 2.3, non-SAS with tow. 2d BL with 2.3, non-SAS without tow. 2d BL with 2.7, non-SAS with tow. 2d with 2.3, SAS, with tow. 2d with 2.3, SAS without tow. 2d with 2.7, SAS, with tow. 2d with 2.7, SAS without tow.
Basically trying to figure out BL suspension and the other models that have the SAS option. I don't know if tow pkg is going to make a difference but the only way I can tell is by looking it up by VIN in Microcat.
We are looking at putting together assembled units/packages which will eliminate the need to disassemble your current stuff to get the top plate, insulator then have a shop put it all together.
ETA: You can DM your VIN for privacy sake. I put it in the part system, find the suspension, print and delete the VIN.
GToddC5
Todd
South Jersey
www.bronco6g.com
DMing you now, for "2d BL with 2.3, non-SAS with tow"
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’m certainly curious how different the springs are for a BD 4DR SAS is compared to BL 4DR SAS. The weight difference is only 200-300 lbs stock.
Gotdesl
Alan
Rifle, CO
2016 Ram 3500 Megacab 4x4
Just sent you my VIN for 2.3, 7 speed Badlands without tow or SAS
webspoke
Stan
Pilot Point, TX
F450, GT350
2d BL with 2.3, non-SAS without tow - 1FMDE5CH4MLA74054
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
May want to check manual vs auto while you’re doing this. Don’t think there will be a difference, but there may be.
mpeugeot
Dude, you should have just asked, I have an entire database!!!
2d BL 2.3 non-sas with tow - Manual 1FMDE5CH3MLA76846
2d BL with 2.3, non-SAS without tow - Manual 1FMDE5CH0MLA70745
2d with 2.3, SAS, without tow
2d BL with 2.7, non-SAS with tow 1FMDE5CP7MLA63055
2d BL with 2.7, non-SAS without tow 1FMDE5CP9MLA76731
2d with 2.7, SAS, with tow. 1FMDE5CP7MLB03750
That's all I had handy at the moment
hellahella
Adrian
Nevada
Ford Bronco
I wish i had a VIN 😭
Dragline
GMC Yukon Denali, GMC Sierra 1500, Honda Civic, Chevy C3500
How about an FE for the 2D 2.7 SAS w/tow?
DM sent
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
This is off topic so, apologies. I don’t have access to Microcat.
Can you get the part number for the sunvisor with Homelink remote from the Lux trim?
mpeugeot
Where did you find dat?
I have been collecting a variety of VINs for exactly this purpose and for Forscan hacking. By using the AsBuilt data I can look at the programming modules and determine where to hunt variables. I have a ton of VINs collected, plus I can generate VINs if I need to...
mpeugeot
SpeedTwin
Ethan
Missouri
F250, Mustang, WRX
Pm sent. 2 Dr BL, 2.3, 7MT Non SAS, tow
