Need VINs for suspension IDs
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
webspoke
Stan
Pilot Point, TX
F450, GT350
2d BL with 2.3, non-SAS without tow - 1FMDE5CH4MLA74054
@flip I want to update my standard badlands above to SAS. Have the shock part #s, What spring codes should I use for a 2dr BL 2.3 auto with SAS?
Currently have these on the truck. Wondering If I can re-use the rear "F" springs
F/R MB3Z-5310-J/MB3Z-5560-F
flip
flip
Phil
IN
www.ruxerparts.com
Fords
I don't have the recipe for a 2d, 2.3 with factory SAS yet but the rear is good for sure. For front, I'm showing a -F for a 2.7 without tow and -L 2.7 with tow. If you can find a member with a 2d, 2.3 SAS, either trans, I can look it up to verify.
mpeugeot
It does seem like many use the F springs in the rear (For example, the SAS OBX and Non-Sas BL 2 doors have both had these springs fitted). The F Spring seems like a pretty safe default and I believe that I have even seen them on many 4 door configurations.
@webspoke, why would you want to decrease your available articulation, this seems like a downgrade, not an upgrade to me. The standard badlands suspension has about 4% more articulation over the Sasquatch, you would be better off with a 2/3" spacer on the lower shock mounts.
Aman
Aman
Northern NJ
I have a VIN for a 2-door Badlands, 2.3, 7MT, Sasquatch, and Tow, but it's not yet built. However, I'm happy to provide the VIN if you would like.
OuterBets
2022 Cactus Gray 4dr OBX
Reviving an old thread here, but @flip is there any update on having pre-made bundles of all the suspension parts needed for the various conversions?
I’ve got a 4d 2.7 non-SAS OBX w/tow that I’d like to convert to the BL suspension based on you and others rave reviews of the BL ride and handling.
5280Bronco
Denver
Flip will chime in, but just to let you know, the cost has gone up quite a bit. Ugh.
