Need Aftermarket Upper Control Arms?
met
Bloomington IN
Hey all..a buddy and me installed Bilstein 5100’s on my big bend yesterday. Took it in for an alignment today. Is this showing me that I should get more articulating upper control arms? We set the front at clip 3 which is about 2in and the back at 4 which is about 2.1in. I’m curious- before and after below.
Ford Bronco Need Aftermarket Upper Control Arms? IMG_3975
Ford Bronco Need Aftermarket Upper Control Arms? IMG_3976
PWillette
Parrie
Maine
The OEM UCA's shouldn't have any issue's dialing-in for 2" of lift. Who did the alignment? The camber and caster readings remain unchanged like they didn't make any adjustment.
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
Agree. It looks like they only set the toe.
Oldhippie
Barry
Santa Cruz, Calif.
2” lift is about max for the stock uppers…ya need to look at the caster adjusters to know how much adjustment they have left…but yeah, it looks like they didn’t even try…
kodiakisland
Arkansas
The stock UCAs are pretty dang good for what they are. They should handle that lift just fine. I'd demand a refund or ask them to complete the alignment. All they did was set the toe.
met
met
Bloomington IN
So I went back and asked why they didn't touch the caster or camber. They put it back up and got it closer but still not in spec. Dude said 'there must be some trick to it' and gave me my money back. Another guy is saying I must get new UCA's. I'm going to take it to a dedicated alignment shop tomorrow. We shall see...
Sitruc_btb
Curtis
Chandler, AZ
2022 Bronco Badlands
The trick is to adjust the lower arms, haha. It's not as cut and dry as adjusting toe, but once you see the adjustments on the rack, you can dial in the camber and caster.
Aftermarket upper control arms add some positive caster to help after lifting a vehicle.
