Need advice: Bilstein 5100 vs. 6112 (or mixed setup)
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I love my 6112s, but I also tow near max weight, and have a good amount of gear regularly in the vehicle which is specifically why I got them.
They can be firm, but very planted. Nose dive and leaning from turns feel so much better. Rides pretty flat, in a good way.
They've been a great upgrade over HOSS 2.0.
I do mostly slow and technical, but I actually like them quite a bit at desert running speeds around 60-70mph as well.
I had no issues reaching 70 mph on the Moab off rodeo sandy two tracks. This was a stock Badlands 4 door with HOSS 2.0.
I have the same on my 2 door Badsquatch, thinking of 8112's when the time comes.
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S, 14 JK Rubicon
If you can find some HOSS 2.0 Bilstein takeoffs like-new for $300-400, I'd go that route. And then go 34" tires. So yeah, the non-Sas Badlands is really all you'll need and it should be a good deal compared to other upgrades out there.
Hoss 2.0 takeoffs for $400: You are gambling with premature failure and you have no idea if you are getting the proper spring rate.
Bilstein 5100 for $600: You are getting new shocks and are reusing springs of the proper weight unless you've added a bunch of stuff. Plus, you can set the ride height. Add a winch? Move the circlip one notch.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Details, details... lol Fair enough, all good points.
dgorsett
colorado
F250, Mustang, Explorer
Running 5100s with 1.5 and 1.7" lift for 3++ years, very good, inexpensive and holding up to mixed use. installation isn't too bad, mark and drop lower control arm, compressing the spring can be frightening. If/when I replace I'll probably go Ford Performance which I understand is a Bilstein 6100 with a fixed 2" lift.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
This seems informative...
