Are UCAs needed for maxed out Bilstein 6112?
98infinity
Alberta
16 F150, 20 Road King, 22 Bronco
Are UCAs needed for maxed out 6112s?
BigMeatsBronco
Allan
2021 FE 2 door
As I've shown in threads, MOST UCAs are made with too small of a ball, so then even with misalignment spacers the joint has less angle available than OEM ball joint. HOWEVER, superior companies like APG make theirs with HUGE balls and this allow more misalignment spacer for the same size bolt, also ICON has their Delta Joint Pro which is an improvement over OEM as well....so both of theirs does offer increased angle.
research before you buy, most are just bling without ANY improvements!!!
Cajun Czar
Robert
Louisiana
F-150
What’s your thoughts on SPC and JBA UCA’s?
98infinity
98infinity
Alberta
Cajun Czar
Robert
Louisiana
F-150
They both use ball joints so I wanted to see what @Big Meats Bronco’s opinion was.
Rick Astley
Up Doug's ass
d
I'll repost this again, again. But you do need to have more knowledge on what an UCA is doing and what you're trying to solve more so than a blanket "will this work".
There is an excellent video you should watch on thesubject.
Cajun Czar
Robert
Louisiana
F-150
Another informative video.
kodiakisland
Arkansas
The easiest way to find out is install the coilovers and check the alignment. I’m 26.5 inches center axle to metal fender and just in alignment, nor do they bind at full droop. I’m sure it will vary from vehicle to vehicle, but the stock UCAs are pretty dang good.
