Multiple sensor failures
ktownsensation
Trav
canada
2019 Ford Raptor
Hi there guys figured I would post this to see if anyone had anything I could check to diagnose a new issue I’ve been having on my raptor. In the last bit of damp weather I’ve been getting the dash lit up from time to time with abs failure / forward collision warning failure /hill start assist failure . Amongst others. This also leads to no goat modes or advance trac . Shop lead times to get this even looked at is over a month away.
Leading to think it is a loose or bad front collision sensor or . Maybe an abs sensor going.
PWillette
Parrie
Maine
Have you checked your battery? Low battery voltage and/or loose connections have caused issues for many.
Brncool
San Diego, CA
2022 Bronco
Have you tried plugging in an OBDII scanner yet to get fault codes?
ktownsensation
ktownsensation
Trav
canada
2019 Ford Raptor
Those are the exact messages I got when I broke a Wheel Speed Sensor.
That said, DTSC code told me exactly which one it was. Although I kinda knew it was the one I broke yanking out.
Note - the ProCal tool does not show these codes, it only appears to show ECM codes, not other modules. Forscan showed it, and the cheap iPhone app with the MXLink showed it.
ktownsensation
ktownsensation
Trav
canada
2019 Ford Raptor
Friend that owns a garage plugged in the raptor looks like it is a malfunctioning abs sensor on the front right.
AK SNO RIDER
Ty
Alaska
Most likely a wheel speed sensor. After all these years Ford still hasn't figured out weatherproof connectors.
ktownsensation
ktownsensation
Trav
canada
2019 Ford Raptor
And to top it all off this part is on national back order across Canada ….. guess it’s more of an issue than it seems hahaha just more good quality part
