Multi Function Digital Display by Wagner Tuning
Gluestick
Josh
Nashville
instagram.com
Looks fixable to me. But I’ve got to work with the other drivers insurance which is no delight.
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
Got mine, yeah need to use the obd port. There’s no instructions available for this in their install guide directory. Also a fuse tap and a usb plug in the package.
What’s the fuse tap and USB plug? Does it have to connect to the fuse box and plug into a USB port, in addition to the OBDII port?
Can you take a picture of what it looks like before installing?
If I wanted to use the display as a handheld unit instead of mounting in the HVAC vent, I am wondering it it’s fully enclosed or if I could make a 3D printed case for it.
seananigans
Sean
Jersey City
2022 Ford Bronco Wildtrak 2.7l
I think it gives two options. Guessing obd port is one and maybe the usb and fuse as a separate but I don’t think that usb port has the info needed. Maybe its for when you pop it out and can usb in computer to get data logs out
seananigans
Sean
Jersey City
here you go.
Ford Bronco Multi Function Digital Display by Wagner Tuning IMG_1982
Ford Bronco Multi Function Digital Display by Wagner Tuning IMG_1981
DarthLincoln
Chuck
Nice!! Looks like it could easily be mounted on a dash rail instead with a cellphone-type holder. I would just need to deal with the cable connections in the back.
Thanks!
DarthLincoln
Chuck
That definitely makes sense. Better than downloading logs wirelessly. Maybe the device can also be updated via the USB connecting to a laptop.
seananigans
Sean
Jersey City
Yeah I think that is definitely an option. Like a small phone
jayr1959
Jay
Delaware
2015 Jeep JK 2DR 2008 Saturn Sky Redline
The USB is to update firmware and also make custom changes. I downloaded the software but have not installed it yet.
jayr1959
Jay
Delaware
I am going to try mounting it on a small mobile phone mount.
seananigans
Sean
Jersey City
Any idea if we need to use a fuse or will the obd provide it enough power? Which fuse are you going to use?
jayr1959
Jay
Delaware
jayr1959
Jay
Delaware
My MacGyver job. I mounted it to my procal until my cell phone mount arrives. I had to use a Micro fuse tap. I used fuse 2 under the steering column. I know it's hot on ignition. I placed a piece of foam between the display and the pro cal to account for the wire connectors and cut out a channel for the OBD cable. Now to figure out how to set it up.
Ford Bronco Multi Function Digital Display by Wagner Tuning IMG_0292
jayr1959
Jay
Delaware
Some screen shots. I scrolled down and found the Bronco file there are 3 listed.
Ford Bronco Multi Function Digital Display by Wagner Tuning IMG_0299
Ford Bronco Multi Function Digital Display by Wagner Tuning IMG_0300
Ford Bronco Multi Function Digital Display by Wagner Tuning IMG_0301
Ford Bronco Multi Function Digital Display by Wagner Tuning IMG_0303
Ford Bronco Multi Function Digital Display by Wagner Tuning IMG_0302
