Multi Function Digital Display by Wagner Tuning
Ducati1098
There is most like a PID for oil pressure on most Ford's but its not a real reading. Its a inferred reading from other sensors to get to a calculation. So to a point regardless of what PID is there to see it or not its not a true reading.
All 3 bronco engines have an oil pressure sensor, so it shouldn't be an inferred reading if the Wagner display is pulling data from the PCM.
Squirrel13
Brad
KY
I believe they have pressure switch which can trigger a check light. Banks said they don’t have pressure transducers to extrapolate a pressure reading. Out of curiosity can you how many terminals are on the switch? I’m guessing 2. I would think a 3 wire transducer with a reference wire is needed
Ducati1098
I believe they have pressure switch can trigger a check light. Banks said they don’t have pressure transducers to extrapolate a pressure reading. Out of curiosity can you how many terminals are on the switch? I’m guessing 2. I would think a 3 wire transducer with a reference wire is needed
They have 3 wire sensors which read actual oil pressure. Most if not all new Fords do.
Not single wire switches like Ford used to use to only measure whether it had or did not have oil pressure.
Older Fords like focus st/rs which @chris@pandamotorworks mentioned used the 1 wire switch which was an inferred value.
Squirrel13
Brad
KY
Hmm. Maybe have to poke around and see what I can see
St. Louis
2016 F250, 2013 Ford Focus ST
Very good information. If 3 wire should be actual pressure!
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Pretty cool.
I will say it's usefulness to me would probably be limited to "ooooo look at the pretty dials go up and down". So I guess I'm in the same boat as @mpeugeot —probably not $500 cool.
But it's cool. I likey.
St. Louis
Pretty cool.
Don't forget 10% off right now though making it less than $500 😀
RagnarKon
Bryan
New England
MEAT_GOD
Kuwait
22 Ford Bronco 2dr, 15 Maserati Quattroporte
It's too damn hot to be sacrificing air vents, man
St. Louis
It's not double the price of a Banks iDash cool.
To install properly seems they are comparable in price. I dash + gauge pod isn't much cheaper than a custom fit product for your bronco
RagnarKon
Bryan
New England
Kind of an unfair comparison.
The iDash SuperGuages don't log data, just displays. This thing logs data.
The iDash DataMonsters DO log data, but they're $470. And once you include the necessary mounts you're easily over $500.
