- Josh
- Mar 23, 2023
- 17
- 674
- 757
- Nashville
- Website
- instagram.com
- Explorer ST, Bronco Badsquatch
- Badlands
Alright, I will pull the file I’m using for the widget display currently, but I’m noting some challenges:
Observations:
the load and boost sensor value widgets topped out when I floored it on the interstate on ramp to see what the max values were. But then they never came back down.
The boost sensor as a horizontal bar does a dance that’s somewhat unpredictable compared to the one in the dash.
none of the temp widgets match the engine or transmission temps in the dash.
the battery voltage here is good, you can watch it changing as you motor along and appears to be more direct than the one on the dash.
The gear sensor is good, but it doesn’t know what to do with P, R, N - will give values like 50, 60, 70. The gear widget, by contrast, is more interesting and displays well leaving those values as “-“ instead of some mapping to a letter. But it also displays “-“ for gears 9 and 10. I haven’t played with the user tables but maybe there’s a way to do lookup values based on input values as a mapping but I’m not sure.
the boost values don’t make a lot of sense to me. It shows a lot of negative values including some large negative values. It topped out at over 200 as you can see. Now I never saw to my recollection the boost psi on the gauge read above 18.x.
and you see two of the ANx sensors never show a value at all.
Observations:
