Mud guards again
Severum17
2024 Badlands Bronco
2024 4 door Badlands Sasquatch. Looking for something to fill the gap between the rear of the front flare to running board and the front of the rear flare to the board. Dont need the big guards. Just something to fill that gap.
aermtr
Don
Portland Or
broflaps.etsy.com
'20 GT500 CFTP, 65 Cobra and '23 Badlands 2.3 7MT
[email protected]. Can at least solve the front. Could add some blank flaps (undrilled) for you if you want to self-solve the front of the rear tires. Fronts are $90 shipped with stainless hardware and I would add the two blanks for $10 more.
Ford Bronco Mud guards again 02ABB66E-4017-4A00-8186-FF31E01C252F2021-11-22_12-59-43_176
Uhdinator
Iowa
Ford Bronco
Made a pattern using card board. Bought some generic rubber mud flaps. Drill 2 holes in rock rail plastic end cap. 1 bolt under it to remove it. A couple of L brackets and a few screws and washers. Drill one hole in bottom lip of fender flares. Used sheet metal self tapping screws to screw into rock rail end cap. Best part is you can make what ever shape or size you want. Trim a little to refine it if need be. (touch up screws with flat black paint)
Ford Bronco Mud guards again 462557340_2502180276839776_1893988462159385226_n
Ford Bronco Mud guards again 462542345_447279967967681_8824699099987774104_n
Ford Bronco Mud guards again 462542196_578738807916924_2536049151977912324_n
Ford Bronco Mud guards again 462575812_986513873514657_772699999022122768_n
Ford Bronco Mud guards again 462546990_891234469382834_2020543830924820324_n
GI_Jo_Nathan
Jonathan
I've had these for a long time and I really like them.
IAG I-Line Rock Rail Side Mini Mud Flap (2pc) for Ford Bronco 2021+ 2/4 Door (Not Compatible with Hoop Step Rock Rail Option) https://a.co/d/bSQ4Wox
Ford Bronco Mud guards again Screenshot_20241028_213809_Amazon Shopping
I love DIY mods the best. Bet those last longer than a lot of pre-fab kits.
