Mountains2Metal's New Flip Down Attic Shelf
Ninjak
Miami
WTB for a slant back! I know I know...even rarer than the 2 door! But would still be nice!
broadicustomworks
Hanging Rock, North Carolina
I picked one up at SCE and am quite happy with it. No rattles and the drop down feature was exactly what I wanted and needed.
Highly recommend!
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
mine rattles 🙄
Mountains2Metal
Mountains2Metal
Nick
Eastern, NC
2012 F-150, 67 Bronco, 94 Range Rover
mine rattles 🙄
Most likely an alignment issue. Loosen bolts on top of roll bar, push tray towards front of vehicle and tighten the bolts back up. Check the side brackets for loose bolts as well.
DriveAllNight
Dan
N.J.
I will give this a try - thanks
Felix808
SRV CA
mine rattles 🙄
Is it empty? Is it something being carried in it causing it to rattle (metal on metal) ? You can probably adjust it some & solve the rattle. Also don't forget to tighten it up again every now & then.
Brostango
Bay Area, CA
2005 F150 Crew, 2016 ATS Coupe
Any chance someone with a soft top has a side view shot with the top down and attic up?
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
mine rattles 🙄
What rattled on mine were the pins. I was thinking of plasti dipping them but ended up just wrapping them with electrical tape. Problem solved. And I can still pull the pins whenever I want no problem.
mjp2
NJ
2021 Cyber Yellorange Bronco Badlands
Ford Bronco Mountains2Metal's New Flip Down Attic Shelf 1746713183352-w7
Wheeled like this all day.
The mat-looking-thing is my Dirty Dog 4x4 headliner folded back and stowed on the attic shelf. Let us wheel open top all weekend and still drive home with some sound deadening as I reinstalled the headliner before pulling away from the campground.
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
I have one and don’t think there’s anything “flimsy” about it. When you load it with 40# of stuff, it’s easy to grab in the center, lift and latch. When you go to unlatch it, you’re reaching in, arms extended and spread wide apart, pressing the latches and letting it down w/o dropping it. That is difficult for this old man. If you’re young with lots of upper body strength, not a problem. So I unlatch one side, then the other and lower it down. There is enough play in the hinge pins and latches that when one side is unlatched and dropped down there just is a very little bit of twist in the basket. In the second pic, the right side is unlatched and hanging on its own, perhaps an 1“ below the latch.
IMHO, making it stronger so it doesn’t twist at all just adds unnecessary weight and cost. I’m really happy with it and as you can see I have the lower shelf too. YMMV
is the tray below the drop down the one that flips up or is it fixed in place?
contented
Karl
Central Fl
BMW M2 Competition
It flips up. More expensive than the fixed shelf, but worth every penny if you haul bulky things occasionally. E.g., someone gave me a decent size knock-off big green egg for hauling it away. Flipped the shelf up, took the egg out of the stand, put the very heavy SOB in, secured it to the four tie downs, took it home.
M2M stuff is expensive, but very well made.
Jim05
Culpeper, VA
www.guildva.com
2023 Badlands
Found another benefit of the flip-down attic shelf -- I installed it with the @Dirtydog soft top headliner and now have the ability to flip back the headliner and run it strapped to the shelf rather than having to completely remove it when I want the open air feeling.
I just have 1 bungee around it here but it was all low-speed stuff. Add 2 more and I'd have no concern running down the highway like that.
How is the access with the top in place from the tailgate, please? The hardtop obviously has plenty of access with the flip-up window. Our soft tops would appear to be an exercise in frustration. TIA.
