More off-road lights = better visibility?
Status
Not open for further replies.
suparee
Renee
CA
suparee.com
Jeep Gladiator JT
We ran a test to see if more lights really means more brightness. So we randomly picked up a bunch of off-road lights and put them head-to-head against our SUPAREE HELM 7.
First off, here’s all the wiring that came with the multiple-light setup, and honestly, it was a lot. The install process was definitely not easy.
Ford Bronco More off-road lights = better visibility? HELM 7 VS 亚马逊灯V2(4)
Ford Bronco More off-road lights = better visibility? HELM 7 VS 亚马逊灯V2(3)
With the HELM 7, we only needed a single 1-to-2 plug-and-play harness. Much cleaner, much simpler.
When it comes to overall beam spread, the SUPAREE HELM 7 clearly had the edge.
Want to see how it actually performs in real life? Check out the video.
Based on the comparison, the SUPAREE HELM 7 does seem to come out on top, with a cleaner wiring setup, brighter output, and wider coverage. That said, the multi-light setup isn’t without its strengths. Its biggest advantage is price. It’s genuinely inexpensive, and even when combined, it still costs less than the SUPAREE HELM 7.
But we’re genuinely confident in the quality of the SUPAREE HELM 7. If you’re looking for solid performance and good value, it’s definitely worth considering.
Click the link to see more details ,there’s also a special offer available right now:https://suparee.com/BG6F260109
If there are any other tests or comparisons you’d like to see, drop a comment below. When it comes to off-road lighting, what matters most to you?
CitrusBronco
Everglades
Citrus county, FL
Everglades
FYI
Your video link does not work when I click on it.
RobWTX
There definitely is a point when the higher number of lights (pods) is too redundant, and won't offer more light, they cover the same area.
That said, the Helm 7 seems pretty good coverage wise!
Draughon
Daylon
Dallas
BMW 4-Series
More lights! MOOOOOOOOOORE!!!!!
Ford Bronco More off-road lights = better visibility? BBNP Bronco
helifino16
Ron
Mount Sinai, NY (Long Island)
For me, it's not so much about seeing as BEING seen. Too many people are so focused on everything else except what's going on outside the vehicle. I actually watched someone last night on a Facetime call driving along.
Doc TOC
Los Angeles
Expedition Max, Fusion Hybrid, BMW 5 Series, HD Road King
If only that was an apples to apples comparison.
What a waste of time and money to make something look so extreme and messy looking. As if anyone would actually do that, except your marketing guy.
Your "comparison" told me nothing!
Except you have money to burn.
Other YouTubers have been more informative with better quality analysis.
Learn from them and come back with something better.
Status
