MIC hard top surface now resembles the moon's surface
DemonGT
Dan
Wisconsin
2022 Badlands
Iv seen Jeeps with similar style hard tops, do they not have some of the issues that the Bronco tops have had?
lwilliams34
Lorne
Wisconsin
2019 Shelby GT350/2024 Bronco Big Bend (Ordered)
I can see already that i am going to have to lower my expectations and calm my OCD with these vehicles. I think Ford can learn a thing or two from Jeep.
I contemplated owning a jeep, but for me the looks and functionality for what I am using it for just didn't make sense. Plus I wanted the 2 door and even though the Bronco doesn't have a lot of room in the back it is better than the Jeep.
May just order a soft top and use that during the summer and hard top during the winter...
Anyone else done this?
SoDak1623
Cole
South Dakota
1996 F150, 2022 Badlands MT
The variance in quality of the tops is crazy. My '22 that was built in March last year has no cracking, delamination, bubbles, etc... It has even been through a couple hail storms that left some small dings in the hood, but no top issues. I've removed the front panels a lot and had the clamshell off once resting on the garage floor and no chipping or deformation from that either. To add, mine is kept outside all year. Snow, Ice, and -40 during winter and 100 degrees in the summer.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
For a 4 door retail price is
$3380 for the clamshell
$980 for the middle panel
$3155 for the front 2 panels
Geez, with those prices the Armadillo top with all the fixin's is a good deal, assuming they can produce them and they're good quality. With these tops, though, nothing is for sure.
Tricky Mike
21 Bronco
Mine hasn't seen the light of day for about 18 months so I'm not sure how it looks. It's irritating that they delayed so many of us for months on Dirt Mountain for tops and still put out this crap.
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
Both of my JKs were hardtops (both body color), never an issue with either top. Not even a leak. They were tough and unfazed by weather including hail and heavy snow and even a small errant tree branch.
I'm putting my dream of owning a 2-door Bronco on (probably near) indefinite hold until they bring back the base model with cloth seats and offer a ragtop from the factory. ;)
These hardtops are garbage, and many will be moldy mush inside within a few years....
Herewegoagain
Maxemus
Idaho
Honda civic
They already offer it. You can order a MIC top from any dealership.
I see about ~95 2 door tops available at a few different depots right now and 33 4 door tops.
I'm glad I got the soft. If I ever get a hard top it won't be thru Ford.
Rusty Sheckelford
Rusty
LA
It cracks me up that they had this solved 30 years ago. Never had any of this on my 80s/90s Broncos. I even took the caps off and on regularly.
Let's be a little fair, those tops were a LOT different than the new mic tops, both in materials and functionality.
A Better argument imo would be that jeep seem to have no problems with their tops, so it shouldn't be taking ford and webesto so long to figure their shit out.
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
Sure but they don’t need to be. Ford just cheaped out and won’t do a foam and fiberglass top. The top on my 1990 was superior in every way except weight.
Ksjrb03
Tx
F250
I don't think my older Jeep hardtops have this double wall bonded honeycomb construction. Instead they have a thicker single wall construction, with some double wall areas that don't rely on honeycomb style bonding.
To me the issues with the Bronco top are:
1) Un-bonding of the outer skin and inner honeycomb.
2) Outer skin too thin - hence more prone to damage, stress cracks, etc.
I think about my kayaks, canoe, and 3 older Jeep hardtops ... and you can beat up the thicker single walls, not concerned with delamination or comprising a thin outer wall.
What's the solution? Get the bonding spread out better. Make the outer skin thicker or out of something more resilient.
The main issue is #2. Waaaaay too thin.
Cost is always a driver in these decisions, but the reason Ford went with this design over the tried and true methods Jeep uses, was weight. The same reason our interior panels are ridiculously thin and flimsy. Bronco had weight issues and during design they cut a pound anywhere they could.
Midnight_Blue
Jeremiah
Los Angeles
This is why I didn’t go for the MIC 2.0 recall nonsense and instead kept the OG top; it looks better than the replacement.
Desert_Brush
SoCal
2015 Mini Cooper
I picked mine up October 2022 and found a crack Feb 2023. I plan on taking it in at the 2 &1/2 year mark in April 2025 so they can fix it well before the warranty expires with hopefully a new version that isn't made of cardboard and resin.
Ford Bronco MIC hard top surface now resembles the moon's surface MIC Top Crack Feb 2023
Ford Bronco MIC hard top surface now resembles the moon's surface MIC Top Crack Location Feb 2023
