Manual sway bar disconnect
EGSquatched
Central Ohio
23 2dr Base Squatch
Any issues with removing the links but leaving the sway bar in place to try it out for awhile?
Fordified1
Bob
Mid South Texas
Nope, just take the bottom of the link off and zip tie the link to the sway bar.
EGSquatched
Central Ohio
23 2dr Base Squatch
Right on, going to do that this week and run it for a month to get a feel for handling changes. Thanks!
Fordified1
Bob
Mid South Texas
You may not like it disconnected with the extra weight of the kayaks on top.
EGSquatched
Central Ohio
23 2dr Base Squatch
Between the kayaks and towing a small camper that is my concern but I’d like the additional flex off-road and the manual disconnects don’t sound too much fun so…
8rent
Brent
I tried that on one side and even jacked up the bronco to get maximum pull on the link and only got it to move up about an inch. Is there a trick to this?
Ford Bronco Manual sway bar disconnect IMG_7269
EGSquatched
Central Ohio
23 2dr Base Squatch
I removed both of mine last week and didn’t need to jack anything up. Maybe try and remove the jack and thread the nut on the sway bar link so it’s flush with the stud and hit it up with a hammer? You can always hit the side of the lower control arm to try and dislodge it.
I have been driving the past week with both removed and the sway bar completely disconnected and while it’s noticeable if you jerk the wheel at high speed I think otherwise it isn’t. I still take on/off ramps at the same speeds I did before which is usually 10+ over the recommended speed without issue. Did 4 hours on the highway Saturday without concern either.
Looking forward to trying it out offroad in a few weeks.
Aonarch
Jack Hoff
MT
Buy once, cry once.
Get an Anti-Rock.
Fordified1
Bob
Mid South Texas
You have to take both sides loose at the same time. But put it back on the ground before you take the other side loose. Those are bonded rubber bushings where it pivots. It’s gonna snap up there if you take the other nut off now while it’s in air.
Yup. Both nuts off - then it will pop up. When you put it back, get both bolts back in before you put a nut back on. Don’t need to jack it up or anything
Take note It has an Allen key in the center of the bolt to keep from destroying to boot. First few times I pulled mine I didn’t even notice and the bolt never spun, then the last time I nearly wrecked the thing.
kodiakisland
Arkansas
Or just pull your swaybar off and be done with it! That is what I've done and it is not sway'ee at all to me. LOL. I pulled the swsybars of my Land Rover Discovery and that thing swayed a lot. The Bronco, still corners real good without.
Pulled mine off also. I can tell a difference but it’s not horrible. Tried that on the Gladiator and it was almost dangerous without it. Been running the Excursion without a front sway bar for a decade.
Yeah. Mines been off a long time now and I don't miss it. The Bronco still drives better than all my 60s-80s 4WDs, so I guess I'm just used to it. I do still remind my wife every time she drives it though to keep her speed down.
8rent
Brent
I'll try that . Thanks
RideClimbNJ
RideClimbNJ
23Wildtrak
I just watched a video of someone installing the automatic disconnect from a Badlands onto a Wildtrak. Once you remove the swaybar it was only 6 bolts to the factory locations to connect it. Then they just wired up to an aux switch. I think I’m going to go this route. Maybe even find the part used.
brkdncr
Southern California
Toyota 86
Why are disconnects sold as a set? You should only need to disconnect one side. The bar will move with the other side but should have full articulation right?
RideClimbNJ
RideClimbNJ
23Wildtrak
The OEM electronic sway bar disconnect is a one piece unit. See pic below.
Ford Bronco Manual sway bar disconnect IMG_6316
