Mall crawlers Do Not Attempt!
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
BigFootie
Wisconsin
Helps to get a bit of heat in them tyres!
internationlriders
Josh
Alberta Canada
2021 Bronco Badlands
Gotta heat up the tires for traction! 😅
At least he made it otherwise - epic fail!
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
Looks like the driver in that video shouldn’t attempt it either.
Smoking the tires accomplishes little other than getting you closer to replacing them.
I'm aware of a principle that applies in other kinds of racing, and plausibly could apply here, that smoking the tires, in this manner, gets the tread surface slightly melted, and makes it stickier, leading to better traction.
Watching this video, it does certainly look to me like that is exactly what is happening. We see the cold tires just slipping, not getting nearly enough traction, and getting a grip only after they start smoking.
But you are certainly right on one point—this does get you closer to needing to replace the tires.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I can smell this video.
Something Wild
KC, MO
2023 Badlands
Awesome
Hey19
JJ
Bethlehem
That was awesome!
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
FYI: Whatever broke during that run will not be covered under warranty. 😂
