Mabett Mud Flap Bracket issue?
SkiSquatch
Neil
BostonArea
2023 Bronco
Anyone successfully install the Mabett Mud Flaps? My brackets don't look right and would end up angling the mud flap backwards...does this look right? @Mabett tried contacting you as well.
Ford Bronco Mabett Mud Flap Bracket issue? 96CDC47F-E6BD-450B-B059-DDACAFBE8224_1_105_c
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
Ford Bronco Mabett Mud Flap Bracket issue? IMG_1643
Ford Bronco Mabett Mud Flap Bracket issue? IMG_1646
SkiSquatch
SkiSquatch
Neil
BostonArea
2023 Bronco
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
Mine seemed the same way at first. Took a little playing with but they did line up correctly.
SkiSquatch
SkiSquatch
Neil
BostonArea
2023 Bronco
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
Thanks...recommendations?
Depends upon how aggressive a trail rider and off-roader you are. I have the RokBlokz, which I like. Rather than re-write a few posts, search "RokBlokz" and attach my username. Removing them is a snap, but re-installing them isn't quite as fast and easy as I had hoped, but I still recommend them.
Check out Gatorback, also this thread. Lots of posts, lots of opinions.
https://www.bronco6g.com/forum/threads/removable-mud-flaps.11680/
And poke around other threads.
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
I have replied.
SkiSquatch
SkiSquatch
Neil
BostonArea
2023 Bronco
Followup - @Mabett has been very responsive and is helping me out with the issue.
Chrome_Pony
Chrome
The Great Land
Mine were kind of similar, but not as severe an angle. If they survive a winter in AK, I'll be impressed, and that will be a recommendation for sure.
My only annoyance with the front pair is that the one mounting location with the most pressure on it is one of those stupid OEM plastic screw mounts. If there was a way for a nut clip and bolt like the other two, it'd be a pretty robust mounting setup.
Grave66
Garrett
WV
2023 Bronco SAS 2 door in Area 51
Both of mine were bent at different angles. I wound up bending both of them to this angle. There is little to no stress on the factory plastic clips. Installed last night.
Ford Bronco Mabett Mud Flap Bracket issue? 20230921_224339
SkiSquatch
SkiSquatch
Neil
BostonArea
2023 Bronco
Thanks....I don't have a good engough vice to bend them. @Mabett was good enough to refund my purchase.
Andyp
CA
I just tried to install mine and the brackets were the same. There is no way it will reach the lower back tab.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
I would try and bend them. But if not - send them back or ask for replacement tabs. I have had my Mabett Flaps for almost 1 1/2 years......Love them. It will be worth the wait. They are just the right height and width. Looks great and performs as should.
Noco
Maryville TN
Toyota FJ Cruiser, Trail Teams edition
Mine worked, but the nuts and bolts are not stainless or galvanized and are rusting.
