Mabett Mud Flap Bracket issue?
BigFootie
Wisconsin
Mine worked, but the nuts and bolts are not stainless or galvanized and are rusting.
I had to replace my speed nuts as they were not long enough for the Heritage fenders. I bought stainless steel ones and Mabett is now using stainless steel screws.
I thought mine would not work either based on the way the bracket looked but mounted up just fine.
SeptuagenerianSasquatch
Randy
Massachusetts
In previous conversations, Mabbet ("Jason") has been very responsive in replacing the hardware with stainless. They replaced mine (took about 2 weeks). Since they're a site sponsor, you might contact them through Bronco6G.
The Mabbet mudflaps are fine for daily drive, gentle offroading, and dirt/gravel surfaces, but not for serious obstacles and rock crawling. I gave up on mine, and gave them to another guy whose Bronco is a daily drive, and went for RokBlokz instead. Nothing against Mabbet--just know what you're buying and what/where it will be used.
Andyp
CA
I would try and bend them. But if not - send them back or ask for replacement tabs. I have had my Mabett Flaps for almost 1 1/2 years......Love them. It will be worth the wait. They are just the right height and width. Looks great and performs as should.
I broke out the old giant vice and bent the driver side bracket. It now fits pretty well. I had to use the supplied clip as the original Ford one wouldn't go in and latch. Passenger side tomorrow
Andyp
CA
Passenger side went on easily with the bracket pre bent to match the other side. The part to be careful is removing the plastic clips. I used a little more finesse on the passenger side and it made the job a lot easier
