- Brian
- Sep 14, 2023
- 65
- 9,026
- 16,127
- Central CA
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Big Bend
The other thing that I would mention if you are wiring up your own pigtail:
polarity matters. The internal coil wiring is color coded standard red (+) and black (-). I know on the m220 you can unscrew the connector body and pull it out away from the diff housing to verify which pin is which. I’m not sure if you can on a m210 as I’ve never worked on one (yet) but I imagine there is a way, even if it’s popping the cover
if you wire it up backwards it may blow the coil (and fuses and your mind) and that is a huge pain in the butt
