Lug Nuts retaining water?
FTBronco9
F-150
Went to get my tires rotated at Americas Tire a couple weeks ago and the guy was telling me that there’s a problem with Fords lug nuts. That because of the seam around the outside, water is able to seep in which will allow the nuts to expand or retract on the stud. Which could cause them to seize up or strip with heat. He said that it’s a known thing and there’s already litigation surrounding it. I found out the case was dismissed earlier this year but I’m wondering if there could be something to this. Anyone else heard of it or think it could be a problem?
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
Change them all now, or you will have an issue eventually with the swelling. I have 3 other ford's all the same thing. Got stranded with a flat on my 2017 Expedition because of these cheap$+:#!? Lugnuts Ford uses. Just change em out, but don't buy the replacements from Ford.
0ne
Nate
CO
Flex
Jeezus, we have to worry and obsess about the friggin lug nuts too? 🥴
Bearcat1
Travis
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
Used to be a Ford tech and yes, they will expand and round off. I would suggest replacing them now instead of when you need to change them out and you are stuck on the side of the road with a flat. A nice locking set can be found for less than $100 online. Even at your local tire shop maybe.
Johnny Mo
Westchester County, NY
teachu2shoot.com
1000000% an issue - had them on my Fusion a well. Ford would not warranty replace them and would only replace them in service dept with the same shit design. Went with aftermarket one piece lugs instead.
flip
Phil
IN
www.ruxerparts.com
Fords
I'm not sure Bronco has the two piece nut like the ones that have this issue.
Bearcat1
Travis
My Bronco had two piece, 2022 BD.
Not sure if different materials or not, but still two piece design.
FTBronco9
FTBronco9
F-150
Headsong
WTF???????????
It's always something. Now I wonder if my replacements suck as well? (Not Ford)
  • Like
Reactions: 0ne
Bearcat1
Travis
Chuckle, I am going to bow out of this thread. I am very happy with my Bronco overall, most fun vehicle I have owned. The oil stick thing kind of pisses me off, but that is about it. I planned on changing the lug nuts before I even ordered it knowing it was probably an issue as I currently own 3 other Ford's with the same lug nuts. I just was answering the ops question, but seems like every thread of this forum becomes a bitch session and I don't want to add to this one. Good luck, cheap $100 insurance IMO and an easy diy.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
To be clear, the lug nuts don't actually "swell". They are 2-piece. They use a 21.5MM socket which is special size. What happens is standard sockets will have a slight slippage combined with the torque of an impact wrench and the top layer of the 2-piece design will be moved out of alignment of the underlying splines causing the impression that it has "swelled". In a worst case of the "swelling", the outer cap will spin freely. One will need to chisel off the outer cap to get to the underlying splines to remove the lug nut. Extra labor in the shop and they will charge you for that along with replacing with the same shit design. If you have a "swollen" lug on the trail or roadside, you are f'ed.
Best coarse of action is to buy a solid (1-piece) lug nut and replace the crap that comes from Ford.
Ground_zero298
Scs michigan
They will swell. Worse in snow states that use salt.
‘21OBX
90Bronco19
2022 bronco outer banks
They are a two piece design and water could eventually infiltrate them. Not likely in on road conditions. They will corrode and swell and generally suck the older they get. Many manufacturers have used the same design for years.
