- First Name
- Cliff
- Joined
- Nov 15, 2021
- Threads
- 4
- Messages
- 1,382
- Reaction score
- 2,439
- Location
- San Angelo
- Vehicle(s)
- Bronco
- Your Bronco Model
- Wildtrak
I'd like to think that the Walker links might reduce or eliminate oscillations because they're first and foremost a damper, which is primarily what's needed in that type of event. Body roll will force one to go up and one to go down, and if they've designed them with even compression/rebound valving, they'll act as one to counter roll moments. I could care less about body roll, and I'm not really concerned with the instability either, but in the rare event that my wife or someone else needs to drive my Bronco, I don't want the wagging to be a problem for them. The ideal solution would be a similar to OEM anti-anti-swaybar setup (should it be called a swaybar in that case?), but short of that perhaps the walker links or a smaller swaybar. Adding a swaybar to the rear might help in my situation more than a front swaybar, as that's where I believe the origin of the instability lies, and the OEM rears are smaller than the front. Makes me wonder if I could get walker links to work on the rear instead.
